Bizhub c654/c754 error code c3102
  • Perfect
    • Jun 2015
    • 10
    Have got 3 of this machine series that were working but all of a sudden came up with trouble code c3102. It turn out to be the fuser motor is not turning at all. Try to replace the fuser motor, Replace PRCB, Replace DCPU, trace 24v signal to PRCB and notice the signal came up at start and disappear before the motor could start or after shutting the front door, side door
    • 23006
    Re: Bizhub c654/c754 error code c3102
    Is the fuser able to turn? I've gotten that jam code when the enduser collects 7 or 8 accordians in the fuser ... stopping the motor. =^..^=
    • Synthohol
      Certified Konica Expert
      • 5817
      Error
      C3102 error code may occur during fusing roller rotation.
      Root Cause
      PS56 Heating Roller sensor not detecting the fuser roller rotation properly.
      a. Clearance between the rotation disk and E ring is minimized to improve the rotation stability.
      b. A fixing screw will be added to the PS56 holder to improve the positioning.
      if you remove the oil roller from the fuser that has stopped that code on many machines.
      it makes too much of a drag on the roller. you can tell if the fuser is really hard to rotate backwards.
      it should be easy to rotate in both directions.
