BH-C-284e, SMB scanning, here we go again....
  • Hansoon
    • Sep 2007
    • 3384
    Guys, is there a special firmware necessary for the BH-C-284e to be able to do SMB scan with the BH-C-284e?
    I have "A5C10Y0-F000-G20-M1" and SMB scanning is not working here. Any DIP-Switches to be set?
    Hans
  • copier tech
    • 8144
    Hans
    GDU-M1 is the latest. Drop us an email should you want to upgrade your C284e.
    • Synthohol
      Certified Konica Expert
      • 5824
      Hans, sent you a PM
      • Hansoon
        • Sep 2007
        • 3384
        Anyone having for me please firmware A5C10Y0-F000-GDU-M1.exe for the BH-C-284e?
        I just donated once again.
        Hans
        • copyman
          Owner / Technician
          • Sep 2005
          • 4700
          You emailed me to send you file. Just sent.
          • Hansoon
            • Sep 2007
            • 3384
            THANKS!
            Hans
            • Duplicator
              • May 2022
              • 245
              Hans
              Yes. Update the firmware and make sure you are on function version 7 (dip switch 25 to hex 60).
              Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
              If I helped you out, please give me a thumbs up! It helps my reputation.
              • Hansoon
                • Sep 2007
                • 3384
                SIGH........
                After updating with A5C10Y0-F000-GDU-M1.exe the web interface of the machine is no longer accesible.
                Neither Firefox nor Chrome nor Edge will work!
                Any ideas please
                Hans
                • Duplicator
                  • May 2022
                  • 245
                  SIGH........
                  Any ideas please
                  Hans
                  Do you get anything in a web browser? Is it just an error about unable to connect or a white screen?
                  • Synthohol
                    • 5824
                    is http server on in admin mode?
                    • mojorolla
                      The Wolf
                      • 2609
                      We have had 107 errors quite a few times and the downgrading, adjusting SSW, then upgrading has resolved the issue several times.
                      • Hansoon
                        • Sep 2007
                        • 3384
                        Its giving an 503 error with the information that the website is “not secure”
                        It is doing it with all browsers. 😠
                        Machine is otherwise working normal except scanning of course since I cannot enter the scan target.
                        Hans
                        • Duplicator
                          • May 2022
                          • 245
                          Hans
                          Is PSWC and HTTP server turned on in admin mode?
                          • Hansoon
                            • Sep 2007
                            • 3384
                            Where to find?
                            BTW, It was working before FW update. Did not make any adjustments to the system.
                            Hans
                            • Duplicator
                              • May 2022
                              • 245
                              Where to find?
                              Hans
                              Utility -> Admin -> Network settings -> HTTP Server Settings. There is a on/off at the top and a setting for PSWC on the main screen with an On/Off. They both need to be on.
                              If they are already on, toggle the HTTP server off and then back on. Then reboot the copier with the gray switch.
