Develop ineo+ 300i not working
  • ilyasoglu
    • May 2024
    • 21
    [Dead] Develop ineo+ 300i not working
    Hello, my printer is a Develop ineo+ 300i model. After printing, the text gets erased as soon as I touch it. To solve this, I reset the printer and adjusted the settings. Later, trouble code C-5360 appeared, which I resolved, but now it is not working. It remains as shown in the attached image, with no panels visible, and none of its functions are active. I kindly ask for your assistance.
  • copier tech
    • 8172
    Try updating the firmware.
    • Ziggy
      • Feb 2018
      • 770
      How did you reset? If you initialized in service mode then you will need to go back through the setup
      • tsbservice
        Field tech
        • 8020
        Can you enter service mode?
        • ilyasoglu
          • May 2024
          • 21
          "I solved the problem. I put the printer into reset mode and then switched to service mode. After that, I performed both physical and logical formatting, and the issue was resolved."
