BizHub C364e big horizontal smudges at fixed position - every page bottom
  • ronsh
    • Jan 2022
    • 5
    We have a BizHub C364e and it's printing out a big chunk of horizontal lines / smudge at every page, always at fixed location - the very bottom of paper. All drums have been replaced and toners all looked fine. What could be the problem? Thanks for any input.
  • Synthohol
    Certified Konica Expert
    • 5799
    worn trans belt or that the cleaning blade on it failed.
    has a tech seen it yet? a tech would stop the process at different timings and inspect the latent image for where exactly the issue happens.
    then he/she would replace the worn transfer belt maybe get lucky and just remove a stuck paper/label fragment from the cleaning area.
    thats my guess.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4623
      If print defect is only black than only thing that would cause that is the drum. If drums are new as you say you still have a bad/defective black drum unit. Were the drums genuine or aftermarket? Either way exchange black drum with a new one.
      • Ziggy
        • Feb 2018
        • 692
        Is it long edge or short edge feed?
        • Oystercopy
          • Oct 2009
          • 623
          I just had this same problem last week, but it was caused by generic, defective toner. Had to replace all 4 drums and the Xfer belt and roller.
          OC
          • ronsh
            • Jan 2022
            • 5
            Thanks for all replies!! Yes drums are genuine and the stripe is actually not always black, sometimes it shows mixed colors. Paper is just regular letter size and long edge feed. After checking transfer belt, with a good cleaning and completely wiping its cleaning blade, the problem seems to be solved. Turns out the belt is holding lots of waste toners and some dust / hair ...
            • copyman
              Owner / Technician
              • Sep 2005
              • 4623
              Glad you got it fixed. Good rule of troubleshooting is if defect is only one color it's the drum, if multi color it's the belt. You failed to mention this in OP.
              • Synthohol
                • 5799
                i zoomed in on the pic and saw graynbow, it yelled belt to me
                • progoffice
                  • Nov 2008
                  • 334
                  It looks like it might need a new cyan DV unit as well. You can see the trademark zebra pattern on the images.
                  • femaster
                    • May 2011
                    • 1482
                    There is definitely other issues at hand beyond the transfer belt cleaning unit. I agree, it look like there could be a bad cyan dev unit.
