BIZHUB C250i POOR FIXING
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Hello comrades, am working on the above but having a challenge of not fixing the copy.
    The copy comes out but not fixed,the text just rubs off.
    work around; 1. removed the fixing unit replaced fixing film,adjusted fixing temperature to maximum to no vail.
    I have rebuilt the fixing unit but same problem still persists .
    upgraded firmware,but still no success.
    Any assistance much appreciated
  • Thib
    • May 2017
    • 35
    Verify that both black & all colors aren't fusing. Had one last month that I was only printing black test pages. Ended up being the black toner that the customer bought off amazon. If I had printed a demo page I would have saved myself hours of time. If neither are fusing to the page properly it's the fuser. I've had a few like that lately.
    • Woxner
      • Jul 2011
      • 851
      there are new style fusers that will take care of this problem. it comes with a shim and engine settings, after market will make this problem worse
      • Duplicator
        • May 2022
        • 246
        The i-Series has had a rough time with fusers... There has been 3 revisions in our area of the world so far.
        You will also need a new enough version of the firmware to make use of that switch.
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
        • KMFLT3CH
          • May 2017
          • 241
          Just replace it, don't waste your time. These fusers are garbage. i-Series New Fusers.pdf
          There is a good reason why KM removed the expected yield number from the consumables by model pdf for all the 0i models.. because the fusers don't even make 1/3 of their expected yield 😂 Consumables by Model 11-2024.pdf
          • Woxner
            • Jul 2011
            • 851
            newest fuser number AA2JR75200
            • Ziggy
              • Feb 2018
              • 770
              if you have not fusing properly you can turn on engine switches 35 and 57. The engine switches can be found under the advanced security settings. Service mode the press Stop>0>C
              • Oystercopy
                • Oct 2009
                • 623
                I don't suppose its bad, generic toner, right?
                OC
