C368 Yellow light and only on top 1/2
  • Thib
    • May 2017
    • 35
    This is a strange one...
    Only affecting yellow, partial print/light. I replaced sub hopper assy & y drum & dv unit due to a low TCR situation. The dv unit is seated properly and TCR Y is 6.22.
    See image attached
    This gallery has 1 photos.
  • Ziggy
    • Feb 2018
    • 780
    pull transfer belt and make sure the yellow transfer roller inside of belt is still in place. Better yet stop it while doing the yellow test, then pull the belt. that way you could see if yellow is on the belt..
    Edit to add there is also a chance that the laser slit glass could be covered in toner/developer. After all if the TCR went low the developer had to go somewhere. If this is the case you would need to pull the laser(PH) to clean it properly
    • tsbservice
      Field tech
      • 8020
      Absolutely agree that covers almost every possible scenario
      • elmaligno
        Expert technician KM
        • Oct 2009
        • 302
        Replace the belt drive clutch. Trust me
        Field technician since 1994
        • tsbservice
          Field tech
          • 8020
          ITB on this model is driven directly by the driving force of the transport motor. Perhaps you meant 1st transfer pressure clutch (CL5) ?
            • 8174
            See image attached
            Maybe the yellow transfer roller in the transfer unit is not seated correctly or the spring has fallen out.
            • kingarthur
              • 1369
              Did you put an original yellow drum in, or did you convert a black drum to yellow - if so, did you change the front end caps etc.
              • elmaligno
                • Oct 2009
                • 302
                Yes, it is
                • Thib
                  • May 2017
                  • 35
                  Missed this yesterday. Thanks guys! Replaced the TB as it kept getting hung up.20250211_114657.jpg
