Bizhub 550i not boot ROM
  • Quagbih2011
    • Jan 2025
    • 12
    [Error Code] Bizhub 550i not boot ROM
    Plug the USB in to reboot ROOM (I pressed the Stop button + turn on the power), the screen appears like this. I don't know how to handle it. I don't have internet connection. I need support?image.png
  • copier tech
    • 8169
    Does the device come to a ready state if you remove the USB drive & power off / on the machine ?
    • Duplicator
      • May 2022
      • 246
      That is the internet ISW screen. Reboot it with the main power switch. If that doesn't work leave the machine powered on for 15 minutes and let it time out.
      Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
      If I helped you out, please give me a thumbs up! It helps my reputation.
      • Quagbih2011
        • Jan 2025
        • 12
        I turned it on and it stayed like that forever
        • Duplicator
          • May 2022
          • 246
          What happens if you remove all flash drives, and power the copier on while holding the reset key?
          • Quagbih2011
            • Jan 2025
            • 12
            HELP ME
            • Synthohol
              Certified Konica Expert
              • 5846
              go in service mode and turn OFF ISW firmware.
              Machine Update Settings To set firmware upgrading by Internet ISW, and enable or disable various settings. OFF OFF (not to be changed)
              • stronghold
                • Apr 2023
                • 47
                Hi.
                Have you tried installing updates on the firmware?
                Have you updated Boot, CPU1, CPU2?
                If you need help, please contact me in PM
                • Quagbih2011
                  • Jan 2025
                  • 12
                  Originally posted by stronghold
                  Hi.
                  i need you, can you support me?
