Looking through some threads here and I have seen many an instance of where a SW switch is mentioned that has no information whatsoever in the Service manual for the device. Example I saw was a mention of SW 210 to do with Status Notifications.
In the 250i Service manual this switch is not detailed at all, it jumps from 206 - Coverage counter to 226 - Fax Mis-send Prevention.
Another example I have was for the 8Series machines.
If you go into the service manual and go to the Engine FW DipSw list and look at switches 37 and 38 they both say "Not Used". However, there was a bulletin released to do with excessive fuser bearing wear for this machine and lo and behold these 2 switches control Polygon Motor, Fuser and Fan control during standby.
Why do the service manuals, which are only accesible to us techs, not give us the full list, and has anyone complied a full list of what the switches do based on TIB releases?
I have started a spreadsheet myself to track all of this missing info.
Just a curious thought for discussion on a quiet Friday afternoon.
