hello friends. i had a problem with my previous machine (c654e) and it was replaced with a c754e. i found a setting that i didn't have on my previous machine. see photo. basically on the previous machine when i started a photocopy, it already started. with this machine no. i need to give further confirmation. where can i change this setting? thank you very much
Konica c754e copy start
You have to turn it off, then go into copy settings and change the defaultTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
Just want to put this in here. This can be two things: 1. Separate scan on platen glass is turned on which will always do this OR 2. The copy mode is set to always have separate scan enabled and must be disabled permanently then locked in, in admin.Comment
If on the glass it could also be set to duplex everything or offset sort or group is on by default. I had a tech call me the other day with a machine doing this off the glass and it was set to offset sort by default.. He changed the group/sort to auto and it resolved his issueComment
If on the glass it could also be set to duplex everything or offset sort or group is on by default. I had a tech call me the other day with a machine doing this off the glass and it was set to offset sort by default.. He changed the group/sort to auto and it resolved his issue👍 1Comment
instead, to remove this screen after the copy has started? in my previous machine, after starting the copy, the screen returned to the main screenAttached FilesComment
