Bizhub c454 repeat yellow image
  • bobdee
    • Dec 2021
    • 11
    I am using Konica Minolta Bizhub C45. The Machine works correctly until recently the yellow keep repeat image. I have tried the Transfer Belt in other machine and it works fine. When I swapped Yellow and Cyan Drum Units, the yellow Image still keep repeating itself whiles the Yellow Drum Unit Prints correctly at the Cyan Slot.
    Attached is a copy of an envelope printed by the printer.
    • 14514
    Re: Bizhub c454 repeat yellow image
    How often does the fault repeat? Is it always the same shape?
    • adecanmin
      • Oct 2010
      • 291
      OEM toner? You can up the heat in the fuser Thick 1?
      • bobdee
        • Dec 2021
        • 11
        Mostly the same shape and there is bit spread of yellow after the yellow image is repeated. You can check the image attached
        • bobdee
          • Dec 2021
          • 11
          Please this happens to only Yellow. When you swapped the yellow drum unit to either Magenta or Cyan, it prints correct without repeating image. But when you place any drum Unit at the yellow slot, it repeats the image even new drum unit.
            • 22999
            If the yellow developer is overtoning you can see something like this.
              Ok.. missing something.
              When you swap Y to C..it still has the defect on the c now Y drum?
              So.. problem didn't move, what is the other part in image formation chain?
              HINT yellow dev unit.
              It did move with drum swap.. Drum
              • Toxic
                • 697
                I think erase lamp for yellow does not work.
                Have that case on other machine series, unpluged connector for led erase lamp.
                • Woxner
                  • Jul 2011
                  • 839
                  Does this happen on other color copies?
                  • femaster
                    • May 2011
                    • 1482
                    Definitely check yellow development unit as others have suggested, but I was thinking along the same lines as Toxic, that there might by an issue with the yellow erase lamps.
                    • TEST10
                      • Jun 2010
                      • 69
                      When you say that you try other drum units on the yellow and you get the same problem of the repatted image, the yellow development unit remains? have you only tried cylinder unit?
                      Because I remember something similar once and it was moisture in the toner!
                      • bobdee
                        • Dec 2021
                        • 11
                        Please Thanks for your concern. If I may ask, what causes the developer to overtone??
                        • bobdee
                          • Dec 2021
                          • 11
                          Please thanks for your support. Yes, I changed only the Yellow Drum Unit, whiles the Developer Unit remains in the machine. I have never tried changing the Developer Unit.
                          • bobdee
                            • Dec 2021
                            • 11
                            Thanks. Yes, When I swapped C to Y, still the image repeated at yellow whiles printing with C drum there. Apart from the yellow repeats image, the printer prints fine.
                            • bobdee
                              • Dec 2021
                              • 11
                              Thank you, I will try that.
