C203 Will not copy
  • wkwar
    • Jan 2019
    • 61
    C203 Will not copy
    copier will not copy but will scan and print from PC. no error code. where to start looking?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4764
    Start by looking for a new copier That machine has long been obsolete. Don't get me wrong I liked the C203 series and still service a few die hard customers who love them. Seriously sounds like one of the consumables are overlife, or a setting that limits copy operation, etc
    • Oystercopy
      • Oct 2009
      • 623
      I agree, very old machine. However, I've had a few where the consumables were over-life (and even though you have the consumable life extended to the max with the F/W), and they neither copied NOR printed. So, if the machine is printing, I don't think its a consumable end-of-life issue.
      • copier tech
        • 8200
        Since this old C203 will print the image units etc will be OK.
        When you say it 'won't copy' what exactly happens when you try to copy ?
        • Ziggy
          • Feb 2018
          • 802
          Is it possible that it had a scanner or adf code and the scanner has been disabled? This would allow printing but no scanning or copying .
          • copyman
            Owner / Technician
            • Sep 2005
            • 4764
            I was thinking same thing but anytime something is isolated or disabled there is always a message on top of display showing "xxxxx currently cannot be used..."
            • tsbservice
              Field tech
              • 8052
              Author describing is paradox. Without full picture we can't help.
              The only slight possibility is that colour IU is over life and he can print in black but not copy in colour.
              • wkwar
                • Jan 2019
                • 61
                so it does copy, given bad info. it makes very light copies. the last time (few months ag) it did so, we manually added black toner. work for a while not it is back to light copies. i recall the developer showed some low "reading"..is the sensor in the developer going out?
                • Ziggy
                  • Feb 2018
                  • 802
                  Do the prints look good?
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4764
                    Maybe a language barrier with trying to get info, at some point you just give up helping people!
                    Just to be clear, scans and prints look fine, but copies are light?
                    • wkwar
                      • Jan 2019
                      • 61
                      scans good. print light from computer, copy almost faded. last time i manually add toner and help a little. i recall the number on the imaging unit is off.. like it doesn.t need toner but it does need toner
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4764
                        Start by replacing the black Image unit & do gradation adj
                          • 23010
                          Have you done any cleaning? How old are the consumables? Sorry, we have no way of knowing these things. You have to tell us.
                          • Ziggy
                            • Feb 2018
                            • 802
                            Like copyman stated early on . machine has been obsolete for a long time. even if you can find parts I wouldn't put any money in to the machine
