Konica Minolta Bizhub 554e printing and copying blank
  • Khumz
    • Feb 2020
    • 63
    Hello...
    I have a Bizhub 554e that prints and copy blank pages. Even internal print outs still come out blank. I changed dev unit, drum unit and I.T. belt unfortunately same problem persist. Checked toner hopper all looks good. The machine initialize normal, no error codes.
    Any ideas and suggestions please.
  • femaster
    • May 2011
    • 1458
    Run a halftone page and force a jam (by opening the right side door) just as paper passes through the registration rollers. Pull out the drum and check to see if there is any toner / image on the drum and transfer belt. That will hopefully narrow things down a bit.
    • tsbservice
      Field tech
      • 7911
      Mark developer unit by brushing a bit mag roller does it turns?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4530
        Did this happen all of a sudden or gradually get lighter? What is page count?
        If completely blank then I would look at loss of high voltage. Any motors not turning developer unit, trans belt, etc would throw a code. Unless it's a higher meter machine and possible developer gears are bad and not turning mag roller (like tsb posted)
        • Ziggy
          • Feb 2018
          • 681
          also put a small black mark with sharpie on outer edge of drum then pull it out to see if its turning.
          • DMSK
            • Jun 2012
            • 2
            If you access techrep mode , do you see an oil can icon? Your printhead may have failed and it will not trigger an actual error code . It may not register a registration patch on transfer belt
            • Khumz
              • Feb 2020
              • 63
              It seems there is no toner image on both transfer belt and drum unit. Although i did check the transfer belt, the drum unit and the dev unit are all turning.
                • 22932
                You have narrowed down the problem a little. It could be the printhead unit or the MFPB. Can you print an internal test pattern?
                • Khumz
                  • Feb 2020
                  • 63
                  hi guys, thanks for your input i managed to solve the problem. The solenoid on the main drive assembly was stuck and this is the reason why the dev unit was not turning.
                  • Ziggy
                    • Feb 2018
                    • 681
                    Glad you fixed it but you said that the dev. unit was turning.
                    • Khumz
                      • Feb 2020
                      • 63
                      Running the machine with the dev unit externaly connected the drive gear turns.
                      • informaticaoffice
                        • Oct 2019
                        • 13
                        Hi I don't know if you solved it but if you have blank pages both color and black and white.
                        It happened to me and I had to replace the HV Board.
                        Behind the board assy.
