Movie data (Still Image Data) C300i
  • Tiagocang
    • Feb 2022
    • 62
    hello, anyone has a Still Image Data for C300i with microSD, just dont accept the "normal" movie and i cant find the Still Image Data it in KIKU
    best regards
  • Max
    • Oct 2011
    • 561
    There's a firmware with and without hdd. If you scroll down, these a whole list of items you can download. Perhaps it's in there if you pick the one without the hdd. I could be wrong of course.
    Why not have ssd in the copier?
    • Tiagocang
      • Feb 2022
      • 62
      i looked for that but no sucess ill look better today for without hdd firm.....tried to save ssd after 25% issues and no sucess and we change ssd to normal microSD because its cheaper and for this client works good with microSD, just wanna clear the message in the screen no movie
      • Max
        • Oct 2011
        • 561
        Format the ssd in the adaptor. I never had to replace the sdd for any problems. Always been cpu board
        • Ziggy
          • Feb 2018
          • 770
          Found procedure on how to switch from SSD to micro-sd but doesn't tell you where to find the still image data . I will do more research when I have time.
          • Tiagocang
            • Feb 2022
            • 62
            exactly i made everything from that PDF and still cant find the image data for C250i i found for A4 machines and C257i i tried put the image that from that models and always says File NG
            • Duplicator
              • May 2022
              • 246
              For what little it's worth, I don't see anything called "Still Image Data" (or find anything searching for "Still") on the North American Konica dealer portal.
              Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
              If I helped you out, please give me a thumbs up! It helps my reputation.
              • Max
                • Oct 2011
                • 561
                Have you tried the latest FW after you took out the ssd?
                • Tiagocang
                  • Feb 2022
                  • 62
                  yes, the firm version is AA2J0Y0-F231-GC3-RE-990
                  • tsbservice
                    Field tech
                    • 8020
                    They mentioned but seem to forget to put still image data on site.
                    • Tiagocang
                      • Feb 2022
                      • 62
                      UPDATE: After talking with KM they provide me the image data for C250i with MicroSD if some1 need it can pm me
                      resolved ✅
