Magenta toner in black image unit
  • simeismoler
    • Feb 2024
    • 10
    I changed the charge roller in the black unit.
    Why does magenta toner appear?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4705
    Are you saying it was a brand new aftermarket charge roller installed in black drum unit, then magenta toner built up on it? I've rebuilt many of these drum units using all new aftermarket parts and never seen a different color appear on charge roller like your picture. Did you use the charge roller from a magenta unit? Did you rebuild the drum unit with new drum, etc or just replace the PCR? Something doesn't add up and has to be more to this story? Only parts available for Kon/Min drum units are aftermarket.
    • Synthohol
      Certified Konica Expert
      • 5826
      do they run labels?
      ive seen sticky drums getting charge rollers sticky and they pick up whatever toner mist is floating around the machine. look at the gap in the contamination, is it label margin width?
      check the toner filter, see if its mostly magenta too.
      the drum surface looks bad though.
      • kingarthur
        • 1357
        Did you just change the charge roller, because that drum looks knackered to me
          • 23008
          Yes, why did you change a charge roller only on a drum unit that's completely worn out?
