C253 - Web Connection Issue / Firmware Update?
  • rugby_mihe
    • Nov 2024
    • 8
    Hello,
    today I wanted to set up "scan to email" instead of "scan to Box". It wont send email,
    but at this time its my smallest problem. I cant connect to the web service any longer,
    it enforces HTTPS, but there seems to be no valid certificate on the machine.
    Is there any way to totally reset the machine?
    Would a firmware update cure it?
    Mihe
  • copyman
    Owner / Technician
    • Sep 2005
    • 4711
    I don't think that old model will scan to email because of security issues, etc. Years ago many of my customers with the C253 upgraded to the 4 series, mostly because of scan issues. Maybe some others here have work arounds.
    If that machine is working good except scanning I would not initalize or format hdd. You could end up with a machine that don't work at all!
    Firmware won't help because last F/W offered was 2012.
    • Synthohol
      Certified Konica Expert
      • 5839
      agreed, the 3 series is unable to adhere to the current security protocols thus unable to use that feature anymore commercially.
      easy to just scan to usb stick and use from pc
      or upgrade?
      • Black Cloud
        • 164
        The only way to get a machine of that vintage to scan to email that I'm aware of, would be to set up an SMTP relay on a computer within its network and send through the relay.
        As for seeing the Copier's Web Connection, I keep my old Windows 7 laptop around for such tasks, and use Internet Explorer.
        Net+ PDI+ @Remote
        • Copier Tech Specialist
          • Jan 2025
          • 19
          you can refer this link on how to setup smtp relay to configure scan to email in less security protocol machines.
          • Duplicator
            • May 2022
            • 246
            If you need a browser that works on modern version of WIndows for bypassing certs try https://www.palemoon.org/
            Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
            If I helped you out, please give me a thumbs up! It helps my reputation.
              • Jan 2025
              • 19
              An Alternative option is to install Mozilla Firefox and change the below settings.
              (1) In a new tab in Firefox, type or paste about:config in the address bar and press Enter/Return. Click the button promising to be careful.
              (2) In the search box above the list, type or paste TLS and pause while the list is filtered
              (3) If the security.tls.version.max preference is bolded and "user set" to a value other than 3, right-click > Reset the preference to set the default value of 3
              (4) If the security.tls.version.min preference is bolded and "user set" to a value other than 1, right-click > Reset the preference to set the default value of 1
              • rugby_mihe
                • Nov 2024
                • 8
                Hello,
                thanks for all your replies. I could work it out now, and did a total reset of the machine. I can finally log into it.
                Mike
