Bizhub c220 replaced drums with new units, magenta warning still on
  • va2ir
    • Dec 2011
    • 12
    Good day. I am now the owner of my bizhub 220. It works well for me. I just replaces the 4 drums with new units. Restarted the machine and the magenta drum warning still comes on. I swapped the cyan with the mag unit, and the mag warning is still on. Image is fine. Ran some solid pages, coverage is perfect. Any ideas? Also, the clutch motor for the manual feed tray stopped working. Any idea where these can be purchased? Thanks
    Re: Bizhub c220 replaced drums with new units, magenta warning still on
    Would be helpful if we knew where you are located so we can give you help.
      And private messaging me doesn't do one damn bit of good!
      Post your location PUBLICLY!
        New?
        GENUINE OEM or turd party parts?
        OEM toners?
        • Synthohol
          Certified Konica Expert
          • 5851
          Not to be a dick but why a c220? It's an old boat anchor!
          Check the 3 gold pins that touch the drum chip. Prolly not resetting.
          We're they OEM new drums or did you just replace the cylinder and blade?
          The chip is what seems to not reset the warning.
          With a due respect you should have walked away from that dinosaur.
          • copier tech
            • 8179
            If you update the firmware & change a couple of SW in CE mode you can disable this warning & no need to fit new drums.
            • va2ir
              • Dec 2011
              • 12
              All fixed. Thanks for all the help. Working fine now.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4726
                What was the fix?
                Doesn't happen very often but I've had a few bad chips with OEM supplies.
                  Well share with the class..
                  What fixed it?
                  • copier tech
                    • 8179
                    What fixed it?
                    Not that most of us will see a C220 again but helpful for techs in the 3rd world etc.
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      Ha! Sadly, we still have lots of these in service because people around here don't replace stuff until it completely dies, with no hope of revival.
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • copier tech
                        • 8179
                        I feel your pain. Had to order a new C203 fuser last week!
                        • femaster
                          • May 2011
                          • 1514
                          Same here. We have units older than this still in service, and taking care of them is a major PIA! The only reason we can is because we purchase supplies and parts in large enough quantities that we tend to have an abundance of NOS parts and supplies.
                          • copier tech
                            • 8179
                            That is good if you have the budget to do this. I would not want to risk ending up with $1000's of stock i'll never need.
                            • femaster
                              • May 2011
                              • 1514
                              Completely understandable. Really depends on how many machines a company has out in the field under contract. We definitely cut back the stock as machines get replaced and the number in the field dwindles. We don't want a tons of left over stock either. Occasionally we end up with too much of something here or there, but it's pretty rare, and usually not on an item that is expensive. One thing I can say is that the excess stock in parts and toner has been a major help in riding out this drought we are currently in.
