“ Error. This is invalid External Memory. Please make sure the External Memory.”
  • David Beck
    • Mar 2025
    • 27
    Good morning guys, recently I got a fw update here on the forum which would be the latest for c368 but I've already tried to update this machine but only keeps showing N.G on the control board in this update and any other I try, I've already changed the emmc and nothing is still the same
    This gallery has 1 photos.
  • Albonline
    • Sep 2008
    • 1153
    put the old emcc back in and use the tar wipe file. make sure machine type is correct and that the jump drive is actually connected to the correct port first.
    • Oystercopy
      • Oct 2009
      • 623
      I've had this happen many times. It is usually just the compatibility of the USB stick to the machine. I would use the HPDISK format tool from Konica Minolta to format the USB drive first, then reload the F/W and try again. Sometimes that helps.
      OC
      • Duplicator
        • May 2022
        • 248
        That's the checksum check failing on the firmware updater. As Oystercopy said, check your USB stick. Trying a different USB stick may be good idea too. Did you "eject" the USB stick before removing it from the computer? If not, some files may be half written.
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
        • avecosat
          • Jun 2012
          • 305
          Hi, I have the same problem on a C250i. I've tried different firmwares and different USB drives , with the recovery the result is OK. Any ideas? Thanks.
          • Black Cloud
            • 169
            Mine required a new storage board to solve this issue.
            Net+ PDI+ @Remote
            • Reed
              • Feb 2011
              • 258
              I have had this error when a firmware update has failed. I saw it several times on the 8 series. In the service mode you need to go into initialization you can clear the error there its on the same page where you find "clear all data" its a soft tab on the bottom LH side of the display and it will boot up as normal. I am not in front of a machine at this time but I can look monday and post another reply
              • tsbservice
                Field tech
                • 8029
                System error clear.
                  • 8188
                  System error clear.
                  I don't think it is possible to enter CE mode in this error state.
                  • tsbservice
                    Field tech
                    • 8029
                    copier tech I believe they got NG when trying to update firmware on MFP part of update then he put another eMMC and now it has that. So as Albonline said I will put back old eMMC and try to update only MFP firmware. As for system error clear you are correct but it really depends in exactly which state is now machine.
                    • David Beck
                      • Mar 2025
                      • 27
                      I returned the original emmc but it still gives N.G on the mfp, funny that when I put the pendrive and remove the usb cable from the front of the machine and turn it on by pressing stop it starts working again but without the pendrive it turns on this white screen
                      • Black Cloud
                        • 169
                        Did that machine have Bizhub Secure? If so, you may have to repartition the Storage Board.
                        Net+ PDI+ @Remote
