Hello, I hope someone can help me. I have an issue with my Konica Minolta C558. I’m getting a paper jam error in the fuser unit (misfeed detection 13), but there is no paper present. I removed the fuser and cleaned the sensor around it, but the error still persists. I also took out the transfer belt and cleaned all the rollers in the feeding tray, yet I still have no luck. Has anyone encountered this issue before?
Konica Minolta C558 paper jam
Thank you for your input. There is no any error codeComment
Go into Service Mode, Counter, Paper Jam History to get the troubleshooting jam code.Net+ PDI+ @Remote👍 1Comment
Thank you for your input, please see the attached screenshot with the jam errors codeComment
Exit sensor may be toasted.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.👍 1Comment
Is this Actuator broken? This is on the top part of the door that swings open in the middle of the reversing duplex unit.Permanently banned from Konica SSD.Comment
Not sure what all you've done, but let's start simple. Turn the copier off, open all the doors and trays, turn the copier back on. Wait until it notifies you that the side door is open and then close it, close each door and tray separately waiting a few seconds between each one until it notifies you of a jam. Once a jam is indicated stop where you are and check the sensors in that area. If it's the side door I would look at the fuser loop actuator which is just above the transfer roller, it may not be broken but it could be knocked out of place. Another common issue would be the noise dampening pads for the switch gate above the fuser. Just remove them and do not replace them. (sorry I don't have a manual handy to show a picture, but the pads will be on the right side door on the exit/reversal section).
👍 1Comment
Is the jam always there since you turn ON the copier or is it shown after the copy proccess has started?
The last jam you show us in the service mode is 30-03 and thats not in the fuser plus the date is a couple months old, the jam log should be full of the code.
Check the consumables, what is the life of the fuser?
Also, did you check the paper entrance in the fuser (down side)?Comment
