bizhub C458 ADF Paper Jam 66-02
  • kaisa
    • Sep 2019
    • 9
    [Jamming] bizhub C458 ADF Paper Jam 66-02
    The paper is not being fed. As soon as I apply pressure to the top cover, the feed works.
    I've already replaced the feed rollers and seperation roller. Does anyone have a solution for this?​
  • occus
    • 338
    You changed already the torque limiter of the sep. roller?
    Maybe this helps.
    • kaisa
      • Sep 2019
      • 9
      Yes, I replaced it
      • KMFLT3CH
        • May 2017
        • 242
        The top cover latches down via two metal pins. The one at the back probably needs to be bent down a tad so the drive gears mesh better. If when you press down on the cover you notice a lot of play, then try the pin.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4757
          ..... Or make sure ADF top door rear latch hook isn't broken
          • kenpio
            • Dec 2015
            • 202
            Make sure the black patch by the slit glass is clean. That flips down and you can see it.
              • 23010
              Dusty document empty sensor PS1. Clean dust from PS1 in the original tray.
              • Albonline
                • Sep 2008
                • 1153
                I had to adjust quite a few of these pins on new out of the box units at setup.
                • ltdiniz
                  Supervisor de Campo
                  • Mar 2021
                  • 98
                  I was here looking at AllSolutions and found this page, I hope it helps you.
                  This gallery has 1 photos.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4757
                    This bulletin looks like it's exclusive for statement size paper 5.5 x 8.5 when using with mixed original feature?
                    • kaisa
                      • Sep 2019
                      • 9
                      I bent the pins, and it works a bit better now. The problem now is that during the feed process, the paper tray is lifted too late, and then the feed roller no longer grabs the paper.
                      When I load only a small amount of paper, the feed works, but as soon as I load more paper and the tray has to be lifted during feeding, it causes problems.
                      • Slammers
                        • Feb 2019
                        • 156
                        I had this issue, I had to strip the unit down to get to the Lift Up motor and the Lift Up levers that sit under the elevating tray.
                        This was a while ago and I cant't remember exactly, but I found info on this forum about a plate that can get bent in this mechansim. I cannot remember the exact details on what I did to fix the problem though, but could be what you need to look at. My machine was feeding fine then the tray would just randomly drop to the lowest position mid scan, triggering the jam.
                        I would maybe have a look at the lft up motor M5 and its mechanism during operation to see if there is any obvious issues, i.e is it sitting squint, gearing damaged etc. The levers under the tray may need a clean if they have got dusty and may be sticking/binding causing the tray to not move smoothly.
