Bizhub 368e
  • patrickjlc
    • Feb 2015
    • 225
    Bizhub 368e
    Have you ever seen this? I can make copies thru the DF and it comes fine, I put it on the glass and it comes with a little smudge and what looks like out of focus.
    Cleaned all the glass, the rails, checks rhe little platic sliders on the mirrors, etc
    It is the 3rd machine I see with this, with less than 70k. Printing from memory it comes ok, like the test page or config page
    1st photo is from glass, second is from DF and from copier memory
    This gallery has 2 photos.
    • 23009
    Is he DF height set correctly? To me, it looks like the matt is not pressing the original down to the glass evenly.
    • tsbservice
      Field tech
      • 8020
      Ditto I would redo all settings of DF. They should be moving machine leaning on DF.
      I don't like anyone pushing my machine when it is moving on desk wheels.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4723
        That is definitely a scanner issue, there is some hesitation or slipping when scanning starts. Watch scan assembly with lid up while copying. If it was from original not laying on glass all the way there would be a light image not a repeat image.
        What happens if you put a few sheets of 11x17 paper over originl then make a copy?
        Maybe the scanner bed was leaned on and pushed down, lift up on front left corner to raise slightly.
        • Reed
          • Feb 2011
          • 258
          Check the mirrors (mirror 3) I have seen that one be in the wrong position and a small adjustment (1/4 turn ) has fixed the issue. I saw this twice the 8 series color machine
          • copyman
            Owner / Technician
            • Sep 2005
            • 4723
            Agree about the mirror being out of place this would give you an out of focus image like you have. You posted that you checked them so I shared some other thoughts that came to mind. Let us know what the fix was.
            • kingarthur
              • 1369
              You posted it twice, this is what I commented on your other post
              • Black Cloud
                • 168
                I've also seen this from a lens unit. Don't touch the Bird Poop screws, but loosen the leaf springs and shift it within the play that is there. When you get it right tighten.
                Net+ PDI+ @Remote
