C300İ sound problem
  • Ghostlover34
    • Oct 2024
    • 20
    C300İ sound problem
    Hi bro
    There is a noise coming from the front of the Konica C300i model even though the machine has been newly installed. The machine only works for 60 thousand and I have this problem with most 300i models. I think the sound is coming from the waste toner box. Has anyone experienced this?
    I added the audio video
  • Massimiliano
    • Oct 2019
    • 47
    Hi,
    from the video it seems like a problem with the waste toner mechanism.
    I'm attaching the bulletin, I solved it with this method
    • Ghostlover34
      • Oct 2024
      • 20
      hi bro
      is this ?
      • Massimiliano
        • Oct 2019
        • 47
        Originally posted by Ghostlover34
        hi bro
        is this ?
        Yes!
        jpg I can't open
        • kenpio
          • Dec 2015
          • 201
          Have run into this a lot. I took it apart, 12 screws to get to it. Careful not to tip it when you get it apart, the covers fall out, two sizes. After that pretty straight forward.
          • Synthohol
            Certified Konica Expert
            • 5824
            i used to just cut 2 or 3 loops off the shutter spring on the box and it usually fixed the issue with toner backup.
            • kingarthur
              • 1355
              12 screws? - I only remove 3 , then you just remove the part that covers the 3 gears biggrin.png
              • tsbservice
                Field tech
                • 8011
                Same here.
                • kenpio
                  • Dec 2015
                  • 201
                  Guess I will look again.....
                  • Ziggy
                    • Feb 2018
                    • 728
                    see attached bulletin
                    • Woxner
                      • Jul 2011
                      • 848
                      I just spray some lube on these gears. No need to take anything apart
                      • tsbservice
                        Field tech
                        • 8011
                        Nah we used to do that until it just didn't worked on one machine. We carry the part with 3 gear shafts lubed and prepared just to be fit at site.
                        • Boyaka1989
                          • Mar 2021
                          • 19
                          Hi bro
                          https://youtube.com/shorts/ohOoZpLeU34?feature=share
                          goodmorning
                          i had this issue with some c300i and c360i i just hit the side of the gears with hand and it stopped squiking.
                          • tsbservice
                            Field tech
                            • 8011
                            Originally posted by Boyaka1989
                            goodmorning
                            For how long?
                            • Boyaka1989
                              • Mar 2021
                              • 19
                              For how long?
                              well that was a few months back and i never got the issue again.
