MINOLTA BH284e ADF
  • M1963
    • Jun 2017
    • 66
    #16
    Originally posted by copyman
    Well can you at least tell us what solved the issue???
    greetings
    nothing helped
    the values
    4 and 2 were ok
    i installed another firmware
    the voltage on the connector is ok
    • Synthohol
      Certified Konica Expert
      • 5823
      #17
      fwiw ive had to replace at least half a dozen DS boards with similar symptoms.
      i found that if you unplug the HDMI cable from the DS board and boot up. if no codes the DS board is likely toast. if it does code out id just reseat the board on the mfp and try again.
      • tsbservice
        Field tech
        • 8010
        #18
        It's not dual scan DF. Just regular DF624. Plus he did tried another DF.
        • Synthohol
          • 5823
          #19
          aww fudge...
          if you add the board and a 701? will it see it?
          does ADF show up in service mode at all? not system 2, i mean the main sm page
          any 24v at the connector?
          • M1963
            • Jun 2017
            • 66
            #20
            does not show ADF in SM window
            voltage 24V is ok
            everything worked before battery replacement
            • ltdiniz
              Supervisor de Campo
              • Mar 2021
              • 98
              #21
              Hello!
              Why did you change the MFPB battery?
              What was your procedure after changing the battery?
              Did you use any reset tool on this device?
              But let's get to the basics, ok?
              Perform a memory clear on this device and see if it enables the option in system 2 service mode and configure it again.
              • M1963
                • Jun 2017
                • 66
                #22
                Originally posted by ltdiniz
                Hello!
                hello,
                the machine asked me to enter the printer and scanner serial numbers, the cause of this is a dead battery.
                i didn't use the reset tool, i just entered the serial numbers and
                DIP sW 10 hex 02
                i don't understand why the counters reset
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4687
                  #23
                  Usually when it loses serial # all the meter counts are lost. I always use the reset tool with dead battery. I've even brought 4 series machines back to life without replacing the battery. Just can't turn machine off for long once you get it back working.
                  • M1963
                    • Jun 2017
                    • 66
                    #24
                    94 / 5,000
                    I would like to try the latest firmware version so I would like someone to send it to me. BW BH284e
                    • ltdiniz
                      Supervisor de Campo
                      • Mar 2021
                      • 98
                      #25
                      Originally posted by M1963
                      hello,
                      DIP sW 10 hex 02
                      Perform the reset using the reset tool and all the equipment's default settings.
                      Using the most current firmware you have on hand.
                      Until someone makes a more recent version available here on the forum.​
                      • M1963
                        • Jun 2017
                        • 66
                        #26
                        firmware A61F0Y0-F000-G20-M1 Does it support SMB 3.0 ?
                        • tsbservice
                          Field tech
                          • 8010
                          #27
                          No.
                          • M1963
                            • Jun 2017
                            • 66
                            #28
                            No.
                            thanks
