MINOLTA BH284e ADF
fwiw ive had to replace at least half a dozen DS boards with similar symptoms.
i found that if you unplug the HDMI cable from the DS board and boot up. if no codes the DS board is likely toast. if it does code out id just reseat the board on the mfp and try again.We know a thing or two because we've seen a thing or two.
The medication helps though...👍 1Comment
It's not dual scan DF. Just regular DF624. Plus he did tried another DF.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
aww fudge...
if you add the board and a 701? will it see it?
does ADF show up in service mode at all? not system 2, i mean the main sm page
any 24v at the connector?We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
Hello!
Why did you change the MFPB battery?
What was your procedure after changing the battery?
Did you use any reset tool on this device?
But let's get to the basics, ok?
Perform a memory clear on this device and see if it enables the option in system 2 service mode and configure it again.Attached FilesComment
Hello!
the machine asked me to enter the printer and scanner serial numbers, the cause of this is a dead battery.
i didn't use the reset tool, i just entered the serial numbers and
DIP sW 10 hex 02
i don't understand why the counters reset👍 1Comment
Usually when it loses serial # all the meter counts are lost. I always use the reset tool with dead battery. I've even brought 4 series machines back to life without replacing the battery. Just can't turn machine off for long once you get it back working.Comment
Using the most current firmware you have on hand.
Until someone makes a more recent version available here on the forum.Comment
