Konica c554 toner drifting into the drum grids
  • Scarekrow
    • Feb 2012
    • 81
    I have a Konica c454e just over 1000000 copies but it's had new devs original toner, new transfer belt, drums and fuser, the issue is toner is been sucked onto the drum grid and causing blank portion strips on the prints after about 200 copies, change the effected drum, magenta, and then it comes back, what causes this, it had also been doing it on the yellow, the black and cyan are nice and clean.
  • tiagosroque
    Técnico
    • Feb 2020
    • 9
    Originally posted by Scarekrow
    Amigo, boa tarde.
    Muito provavelmente seu revelador está ruim. ja não está mais segurando toner ou os selos da caixa de revelação estão danificados. Causando nuvem dentro do equipamento. Verifique a caixa de revelação e seus selos junto com o pó revelador!
    • femaster
      • May 2011
      • 1504
      Check out the PDF file on the post linked to below. Look at section D on page 3 of the PDF. This is most likely what you have going on...
      https://www.copytechnet.com/forum/te...82#post1588682
      • tsbservice
        Field tech
        • 8013
        Check for blocked air ducts replace filters.
        • tiagosroque
          Técnico
          • Feb 2020
          • 9
          Obrigado pelo boletim. vai ser de grande ajuda !
          • Ziggy
            • Feb 2018
            • 731
            Attaching bulletin with a part number for a vacuum jig that will allow you to not only clean the duct work on the 4 series but on the 8 and i-series as well .
            • copyman
              Owner / Technician
              • Sep 2005
              • 4697
              Agree with others about air ducts. Especially with 1 million clicks. I see you use original toner but what about the other consumables, were they all genuine Kon/Min?
