C750i Poor Print quality
  • barber782
    • Aug 2011
    • 286
    Hi everyone,
    Got a frustrated customer with a C750i, who is not happy with the print quality.
    The customer is printing on 200gsm stock to produce booklets.
    In the other room they have a c458 which they much prefer.
    Recently they have had all drums fitted and transfer belt.
    Counter for colour is around 500k, black 100k.
    Nothing Settings wise under service mode has been modified other than software switch 153 set to 40.
    Firmware is on GC2-RF.
    Using latest PCL universal driver (have tried PS)
    Tried printing file directly from USB with same result.
    Grads look OK, maybe on the blotchy side (especially black.).
    Density calibration has been done.
    Genuine tone used.
    ​​​​I have attached photos of samples from both machines.
    The darker and spotty/grainy image is from the c750i.
    Is this what you'd expect in terms of quality for this machine? Or am I missing something?​
  • copytechman
    • Nov 2008
    • 957
    Weight settings correct for media? If so tweak 2nd transfer values? Just a thought. How does it look on plain paper? (mentioned blotchy gradations, 2nd transfer again)
    A.
      • 23010
      I read somewhere here that there are software switch settings that do improve the image quality. Search for i-series imaqe quality.
      Did I copy out the switch settings? Sorry, I can't find it right now.
      Here it is:
      https://www.copytechnet.com/forum/te...e-series-color
      • Ziggy
        • Feb 2018
        • 801
        sw188 to hex 80 and sw153 to hex 20. reboot and run gradation
        • Max
          • Oct 2011
          • 566
          sw188 to hex 81 I believe. Try on plain paper, if improves then try copytechman suggestion
          • tsbservice
            Field tech
            • 8048
            Have you tried Thick Paper Density Adjustment? It's under Imaging Process Adjustment to be more clear.
            • barber782
              • Aug 2011
              • 286
              Took a risk and replaced the fuser unit, as the counter was around the 600k mark.
              Luckily this actually fixed the problems.
              @ZIGGY You mention switch 153 - which i always set to Hex 40 to replicate the 8 series colour profile. Any reason why you would suggest setting it to 20?
              oh and what does switch 188 do?, as its not on my current list of software and engine switches.
              • Ziggy
                • Feb 2018
                • 801
                Just Information I got from a KM tech. Not sure what 188 does but they are telling their guys to set these to this
