First page bad on 3070L Black issue.
  • nullskull
    Learning
    • Aug 2023
    • 425
    This 3070L is printing the first page/pages poorly. As pictured below the first page for both jobs are smudged with lines running parallel with the paper path. The lines also shift each time and are generally on the one side. The lines are gone either by the next page or more gradually. Usually 5 or so pages. I've cleaned the corona twice and the glass too. I was thinking it could be the drums but because it fades away after the first page I thought it might be something else. What should I look for? My plan was to swap drums next.
    d7b13ba2-47c2-45bb-a418-94c2e8679c5c.jpg 5dd3da58-87ac-411c-899d-c129a4d62fc9.jpg
  • Ziggy
    • Feb 2018
    • 731
    You can try swapping the black drum with one of the other colors to see if the problem stays with the drum
    • Afanasy
      • Aug 2023
      • 25
      Most likely the lubricant has been used up and this compartment is filled with toner.
      • nullskull
        Learning
        • Aug 2023
        • 425
        the lubricant for the transfer belt? Or what do you mean exactly?
        • nullskull
          Learning
          • Aug 2023
          • 425
          I swapped drums and for now there appears to be no problems
          • Ziggy
            • Feb 2018
            • 731
            I would order a drum to have on hand
            • Afanasy
              • Aug 2023
              • 25
              Lubricant for drum of course.
              • nullskull
                Learning
                • Aug 2023
                • 425
                Do you mean the white powder lubricant?
                • Ziggy
                  • Feb 2018
                  • 731
                  I've been working on KM production for years and have never had to lubricate the drum . If you ever use lubricate you use part number A50UPP0100 - Setting toner number 2. This is a special yellow toner designed for lubricating the transfer belt and transfer belt cleaner blade. Do not use the toner out of the bottle because it has a small amount of developer mixed with it .
                  • Ziggy
                    • Feb 2018
                    • 731
                    What is the life count on the drum in question?
                    • tsbservice
                      Field tech
                      • 8011
                      Good point.
                      Yellow toner for older models should be safe too as it has no developer powder in it. I mean C220 and such.
                      • Afanasy
                        • Aug 2023
                        • 25
                        I mean this
                        • copytechman
                          • Nov 2008
                          • 942
                          I always replace the drums as a complete unit, never the parts inside of it when there's a specific problem related to a specific drum colour.
                          Regards.
                          A.
                          • Ziggy
                            • Feb 2018
                            • 731
                            Regards.
                            A.
                            Same, that's why I ask the age of drum
