C754 no 3 hole punch suddenly
  • mrfuser
    • 1622
    Client states that the 3 hole pinch just quit working. Went there and sure enough it only 2 hole punches no matter what you choose. Service mode still shows 2/3 hole installed and no codes or jams. Hole punches 2 in the middle of the page on letter no matter what. Looks like the gear is rotating in test mode just fine to switch between 2 or 3 so no idea what’s up. Any ideas?
  • Synthohol
    Certified Konica Expert
    • 5847
    2/3 hole "decision" right?
    • mrfuser
      • 1622
      Correct. When we choose 3 hole it only does 2 hole no matter what. In service mode I have even switched to 2/4 and decision then reboot and set back to 2/3 with decision and same result.
      • Synthohol
        • 5847
        Have you tried to reseat the connectors?
        • mrfuser
          • 1622
          Yep, very odd
          • copyman
            Owner / Technician
            • Sep 2005
            • 4721
            That is a strange one...
            I'm assuming you have the bigger FS535, not the FS534? Might want to back up settings and initialize the machine.
            • mrfuser
              • 1622
              Iokk, went back and tore apart and
              cleaned it all and reseated all connectors and now it only does a 4 hole punch! Sheesh!!! What’s the deal?!?
              This gallery has 1 photos.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4721
                So did you initialize the machine as suggested?
                If you have the bigger FS535 the punch kit has it's own board. If smaller finisher I would look at finisher main board.
                Maybe update the firmware?
                I found the following on kon-min knowledge base. It's for a different finisher but might point you in the right direction with softswitches:
                KB0025630 FS-532, Off-line Punch will not punch 3-holes (only 2-holes)
                Article metadata.
                8mo ago8 months ago
                This article has 44 views.• 44 Views This article has average rating: 0 out of 5 stars• ( )( ) ( ) ( ) ( )
                FS-532, with PI & PK installed, Off-line Punch will not punch 3-holes (only 2-holes).
                CAUSE: Dipswitch setting 21-6 and 202-1 is set to 0.
                SOLUTION: Set dipswitch 21-6 and 202-1 to 1.
                Originally Submitted:08/27/2018
                • femaster
                  • May 2011
                  • 1514
                  Are you sure you actually set it back to 2/3 like stated in the first quote above?
                  • mrfuser
                    • 1622
                    100% sure. Did it multiple times. Must be something mechanically wrong as now after tearing into it again it does 3 holes only and they are close to each other not like they should be and can’t get an adjustment to change anything in service mode
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4721
                      Best of luck!
