The machine was out of yellow toner and customer kept using it a few days for just black. I installed OEM yellow toner. Customer called few hours later that it is throwing C2555 codes (yellow toner code). Had them check the seal tape on new toner and sure enough there was still a piece of tape. They removed it and thought all was good. They called back and still throwing code. Level history staying at 5.38 % even after trying several manually adding yellow toner cycles.
Thanks for any help
Thanks for any help
