Bixhub 654e lct lit motor
  • jper34
    • Sep 2011
    • 225
    [Misc] Bixhub 654e lct lit motor
    Hi Folks-, would any one have these LCT lift , motor available, for sale?Konica c654E me with a part number,,? Thanks.
    Jaime Perona
    Stonington, CT. 06378
    jper34@gmail.com
    860-912-0230
    860-739-6950
  • femaster
    • May 2011
    • 1516
    Re: Bixhub 654e lct lit motor
    Jaime Perona
    jper34@gmail.com
    860-912-0230
    860-739-6950
    I don't currently have the ability to check the parts manual and grab you the the part number, but I thought you should know...
    Those lift motors are essentially universal. If you have any copier from the 2-series on up that you could grab parts out of, just grab a lift motor out of any of them and it will work. They may look slightly different or be a different color, but any of them will work.
      • 23010
      Did you try something simpler, like looking behind the tray to see if there is paper in the coupler? I've replaced very few of these motors, but I've remove paper frequently from behind the paper deck. =^..^=
      • copyman
        Owner / Technician
        • Sep 2005
        • 4742
        Jaime Perona
        jper34@gmail.com
        860-912-0230
        860-739-6950
        Hi, Are you talking about the LCT that sits on the floor on right side of machine? It's usually the white plastic gear that breaks but if you need the motor I should have it. Believe I have the whole gear / pulley assembly with motor.
        PM me
        • jper34
          • Sep 2011
          • 225
          Thanks Guys,
          Im going to swing by, to check for paper,when I fill paper deck up with paper it will feed paper, but when supply is depleated, the plate isnt lifting to bring the paper, up to the rollers. So it will read add "add paper" .
            • 23010
            That sounds like an issue with the paper empty switch lever, not the lift motor. =^..^=
            • femaster
              • May 2011
              • 1516
              Thanks Guys,
              I agree with blackcat. If the tray lifts at all, you're almost certainly not dealing with a motor issue. I'd focus on sensors and related flags if that is the case.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4742
                Thanks Guys,
                Swap the paper feed units between the 2 LCC trays. I believe they are the same. Real easy to remove, 2 screws, 2 connectors, lift right off top of LCC's. If issue follows to other tray you know it's one of the sensors on feed unit.
                • mascan42
                  • Oct 2008
                  • 485
                  The only issue I ever had with those motors is the coupling breaking off from the customer beating the shit out the machine, but that gives a very different symptom.
