both MFP and Control Board dead
  • rrrohan
    replied
    Re: both MFP and Control Board dead
    well i did have machine type set correctly but on 2nd attempt it did act like it recovered the data.
    but then when it booted up i got TPM error and it thought it side LCT tray and told me to replace K drum and nothing i change in CE Mode actualy saved after a reboot so im thinking the SSD is RIP
  • kingarthur
    replied
    Originally posted by rrrohan
    they did go via insurance and insurance went with the cheapest option, spend $1000 or so on parts/labour
    Ouch - i wouldn't have given the option
  • rrrohan
    replied
    Originally posted by kingarthur
    tbh, if a surge has wiped out PCBs, then the customer should claim on their insurance and replace the machine...you could replace the PCBs, but who knows what will go wrong in a month...6 months
  • kingarthur
    replied
  • femaster
    replied
    omg i just noticed what i did wrong. i set it to machine 1 not 3.
    its a e series.
    wonder if i just change that it will be fixed. ill try tomorrow
    It should work afterwards, unless the firmware you installed was not correct for the model you are changing it to. Either way, I'd probably run the firmware again after changing it just to be sure.
  • rrrohan
    replied
    its a e series.
  • Synthohol
    replied
    sent you a PM. hope it helps.
  • rrrohan
    started a topic both MFP and Control Board dead
    Had a surge wipe out a copier C554e
    Replaced the MFP and after 2 reboots pressed recover data but it sits here for about 15 mins. (did firmware and set machine type as manual says and that worked fine)
    If 2 boards go at the same time and I can not recover data what are my options.
    Manual says replacing both of these at same time is not a option but as far as I can tell it means dont replace 2 new boards.
    Im guessing if the SSD remembers meter reading of say 200k and the control board i install remembers a count of 500k it will inherit the higher meter reading? or will it just not work
