hope someone can help. Customer has a Konica c558 which, when printing or copying a colour background has a yellow sawtooth deletion at the front side of the copy. the image attached is an A3 sheet. I have swapped the dev assembly from another machine, with no change. changed the yellow drum with a black drum and chip, changing the front of the drum spacer etc.(all i had with me at the time, again with no change. Removed the itb and checked the primary rollers for damage and smooth lifting. all seemed ok the that. Does anyone have any more ideas of what could be causing this. thanks in advance.
