I need your help
  • Copier repairman
    • Aug 2019
    • 86
    I need your help
    hello?
    Greetings after a long time.
    I need your help.
    Firmware of the bizhub 308e mono machine is required.
    Help me.
    canonrp@naver.com
    I hope to be of some help to you too.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4665
    Re: I need your help
    Originally posted by Copier repairman
    hello?
    I need your help.
    Help me.
    canonrp@naver.com
    I will send it this time but please make a small donation to this website and when you need help in future it will show you are a contributor.
      • 16374
      If you look thru his posting history, all he does is beg for firmware. Never contributed one red cent.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Just count those red cards.
        • Synthohol
          Certified Konica Expert
          • 5814
          all the "tool to reset meters" posts and "tool to speed up the machine" threads after being told not to post that crap here he still did.
          the bridge has been burned for me. i hold no grudge to anyone that does help him, thats none of my business.
          just wont be me.
          • Copier repairman
            • Aug 2019
            • 86
            Thanks for sending the firmware.
            I wasn't begging.
            It was asking for help.
            I can help too.
            If it's not illegal, I'd be happy to help.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4665
              I wasn't begging.
              I can help too.
              Consider the FW sent the last time I will help you. I have blocked you from contacting me. Didn't notice the red cards otherwise wouldn't have sent it. If you decide to make a donation to this website that will be a good first step to getting future help here. Best of luck
              • Ziggy
                • Feb 2018
                • 710
                What do the red cards mean?
                • femaster
                  • May 2011
                  • 1492
                  It's a reputation ranking. The more green the better, the more red the worse.
                  From the FAQ: Reputation
                  • Copier repairman
                    • Aug 2019
                    • 86
                    [QUOTE=copyman;2201561]마지막으로 FW를 보낸다고 생각하면 내가 도와줄게. 연락하지 못하도록 차단했습니다. 레드 카드를 알아차리지 못했다면 그렇지 않으면 그것을 보내지 않았을 것입니다. 이 웹사이트에 기부를 하기로 결정하셨다면, 이곳에서 향후 도움을 받기 위한 좋은 첫 번째 단계가 될 것입니다. 행운을 빕니다[/인용]
                    Thank you for your help.
                    • tsbservice
                      Field tech
                      • 8002
                      I should admit he tried to make some sort of help lately.
                      Personally I may consider giving him some green cards.
                      • allan
                        RTFM!!
                        • 5462
                        Less red cards you mean Gave him one before you posted based on contributing.
                        Whatever
                        • tsbservice
                          Field tech
                          • 8002
                          Originally posted by allan
                          Less red cards you mean Have him one before you posted based on contributing.
                          Yeah you caught me allan. I don't mind that at all as long it's funny even better when the fun is on my back 🙂
                          Makes me somehow more humble.
                          • L0rdC
                            • Feb 2021
                            • 82
                            in this case I remember this user because he even has a device to modify printers as a profile picture, but for example I have red flags and if you check my history, my comments are to try to help
                            • Gift
                              • Mar 2011
                              • 2459
                              green light sabre -> Luke Skywalker
                              red light sabre -> bad guy
                              Light sabers can also have different lenghts - not shure what that's suppose to indicate
                              I find it funny that his rep seems so overwhelming bad that even "copier tech" isn't happy to help against some ca$h...
