bizhub c284e firmware
  • James0221
    • Aug 2022
    • 5
    Hi everyone
    My firmware update input the wrong type of machine. This caused my machine to not work.
    Any solutions?
    Thank you!
  • Ziggy
    • Feb 2018
    • 789
    Re: bizhub c284e firmware
    Originally posted by James0221
    Hi everyone
    Any solutions?
    Thank you!
    What do you mean by wrong type of machine? If you replace the only time I have had to set machine type is when I replaced the MFPB. Need more detail
    • femaster
      • May 2011
      • 1515
      Hi everyone
      Any solutions?
      Thank you!
      I've never done such a thing, so I can say if this works or not.
      I would think it would be as easy as booting back into the firmware update screen, selecting the machine type button on the right hand side of the screen, and then changing it back to whatever it should be. Once set correctly, update the firmware and hopefully everything is back to normal.
      • copier tech
        • 8192
        Hi everyone
        Any solutions?
        Thank you!
        What makes you think a firmware updated 'changed the machine type' ?
        What issues are you having any errors codes etc ?
