konica minolta mobile print: not finding printer with apple 13 iphone
  • adecanmin
    • Oct 2010
    • 316
    Gentlemen
    It works fine on my android. Apple 13 iPhone konica minolta mobile print cannot find printer. I used both the auto and manual. I can see the interface using a browser. I did not check to see if to see if airprint is enabled on copier. Would that make a difference? The copier is a c220.
  • Woxner
    • Jul 2011
    • 850
    Re: konica minolta mobile print: not finding printer with apple 13 iphone
    its been awhile but i dont remember c220 supporting apple. if it does then air print needs to be on.
    • adecanmin
      • Oct 2010
      • 316
      thanks
      • rrrohan
        • Sep 2011
        • 1977
        Originally posted by adecanmin
        thanks
        i thought only the 4 series onward supported airPrint
        • copier tech
          • 8169
          Gentlemen
          latest firmware this may enable it.
          • adecanmin
            • Oct 2010
            • 316
            I'll try that. Thanks
            • adecanmin
              • Oct 2010
              • 316
              I checked the interface. Nothing for airprint. Too old
              • femaster
                • May 2011
                • 1512
                Originally posted by catherinemarms
                It's possible that the issue you're experiencing with the Konica Minolta Mobile Print app on your iPhone 13 could be related to AirPrint settings on the copier. AirPrint is Apple's wireless printing technology that allows iOS devices to print directly to compatible printers without the need for additional drivers or software. If AirPrint is not enabled on the Konica Minolta copier (C220), your iPhone may not be able to detect it as a compatible printer, even if you can see the copier's interface through a browser. Enabling AirPrint on the copier should make it visible to your iPhone and allow you to print using the Konica Minolta Mobile Print app. To enable AirPrint on the Konica Minolta C220 copier, you typically need to access the copier's settings menu or web interface and look for an option related to AirPrint or network printing. Once AirPrint is enabled and the copier is connected to the same network as your iPhone, you should be able to find and select the copier as a printer within the Konica Minolta Mobile Print app on your iPhone 13. If you continue to encounter issues after enabling AirPrint on the copier, you may want to double-check the network settings on both your iPhone and the copier to ensure they are properly connected to the same network. Additionally, updating the firmware on the copier and the Konica Minolta Mobile Print app on your iPhone may also help resolve any compatibility issues. If you need further assistance, you may want to contact Konica Minolta support or refer to the copier's user manual for specific instructions on enabling AirPrint and troubleshooting network printing issues.
                Not saying it is, not saying it isn't, but if I had to wager any money at all I'd say this is a Chat GPT response...
                It has already been established that AirPrint is not something the C220 can do due to its age, so this entire reply isn't much help at all.
                • Synthohol
                  Certified Konica Expert
                  • 5846
                  LOL, agreed!
                  kinda sounded like Data from TNG.
                  read it again in his voice
                  • tsbservice
                    Field tech
                    • 8020
                    I just stopped reading after first or two sentences...it just doesn't sound right to me and I've lost interest.
                    Good work mate you're patient than me
