Activation Code for AirPrint2.1
  • B0265
    • Jan 2007
    • 718
    Does any of you have the AirPrint 2.1 activation code for a Ineo +450i?
  • emujo2
    • Mar 2017
    • 1579
    Re: Activation Code for AirPrint2.1
    Km has not released this yet..Drop the function version down to 2.0 E
    • Synthohol
      Certified Konica Expert
      • 5847
      CAUSE: Function version 2.2 added support for Air Print version 2.1. A certificate is required from Apple development to allow the functionality on the device.
      SOLUTION: Change the Function Version to 2.1 using software switch settings.
      [Service Mode] -> [System 2] -> [Software switch Setting]
      Software switch number 25 to 0x20 (HEX 20)
      Air Print is still functional using version 2.1.
      • Ziggy
        • Feb 2018
        • 770
        Airprint is now available with firmware G00-M2 and higher current version for the 450i is G00-N4. you can set switch 25 to hex 30 with no problem
        • copytechtrouble
          • Nov 2020
          • 110
          the latest firmware (N4 and M2 i believe) have this issue resolved but if you don't have access to the firmware there is a code on this thread that will enable airprint.
          https://www.copytechnet.com/forums/k...int+forum%3A40
          • tsbservice
            Field tech
            • 8020
            I tried to send you a message but your PM is full. Try this:
            KVX4RPQ7G7FQQRQPC3F6XRWYM2G3TXVV
            • B0265
              • Jan 2007
              • 718
              Thanks for the code. I can't delete any messages in my inbox, it says "You have 65,535 total out of 100 allowed."
              At the moment we can't to upgrade to M2 or N4 on this MFP.
