Strange streaks coming on paper
  • diwakar
    • Aug 2019
    • 37
    hi all
    we have changed all the 4 drums, charging rollers, sponge rollers, developer, image transfer belt, cleaning blades of image transfer belt as well as of drums, but these streaks are not going.
    we are using original toner and developer.
    we have attached the image and the issues are circled red, input is bypass, short side of the sheet entered first.
    machine: km c258
    ps: ignore other marks, they are appearing because the sheet is scanned. also, the alphabets in bottom left are due to print on the back side of the sheet, which appear at the time of scanning.
    any help would be much appreciated. thanks
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Re: Strange streaks coming on paper
    Originally posted by diwakar
    hi all
    machine: km c258
    [ATTACH=CONFIG]55491[/ATTACH]
    If you change developer, it means only powder or developing unit complete? Black or all colours?
    Field technician since 1994
    • diwakar
      • Aug 2019
      • 37
      new units
      • elmaligno
        • Oct 2009
        • 302
        new units
        Possibly you have a bad fuser belt, it is necessary to determine if the fault is repeated periodically, but something similar happened to me and it was that belt.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4684
          So you are using aftermarket drums, blades, charge & cleaning rollers instead of complete units? These parts are not available separately from Kon/Min so must be aftermarket. First I would look at the black drum unit specifically the charge roller. Second, pull the transfer belt and see if the mark is on belt.
            • 23007
            What is the distance between the occurrences in millimeters? Whatever that number is:
            distance/3.14159265=diameter of the roller causing the issue
            It gets a little more complicated with the developing roller, since it usually counter-rotates with respect to the drum. But for everything else, this formula works nicely. =^..^=
            • copyman
              Owner / Technician
              • Sep 2005
              • 4684
              Would be nice if K/M had a defect ruler like HP and some other OEM's have.
              • tsbservice
                Field tech
                • 8009
                The distance between marks varies.
                Author, why you're doing tests SEF and from bypass?
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4684
                  I saw the defects on sample weren't perfectly spaced apart and posted my opinion on what was causing them.
                  My comment about a defect ruler was in general to help when defects were evenly spaced apart.
                  • Ziggy
                    • Feb 2018
                    • 724
                    You might have more than on crack in the fuser belt
                    • JasonSBE
                      • Apr 2014
                      • 184
                      I'm also leaning toward fusing unit. The good news is that normally you can see any cracks or indents in the fusing roller so you don't need to replace it necessarily in order to identify if there is an issue.
                      • DoomedManzz
                        • Nov 2022
                        • 1
                        hi all
                        machine: km c258
                        Looks to me like a fuser belt, have you tried testing a new fuser in the machine? or do you have a machine you are able to put the fuser into and see if this is the issue? I have seen this once before on a KM 224, judging by the spacing and repeating pattern it would have to be the belt.
                        Best of luck to you
