C250i fusing problem
  • jwai
    • May 2018
    • 517
    Hello,
    Several bizhub C250i sometimes have fusing problem, toner cannot fixed on paper.
    check the unit is ok, increased fusing temp. but no luck
    replace new unit solve it, what reason cause this?
    F/W G00-J9
    Fuser life more than 70%
    • 8205
    Re: C250i fusing problem
    Originally posted by jwai
    Hello,
    F/W G00-J9
    We have seen this a lot, the fuser units on the i series seem to be very poor. The only option is to replace it.
    Hoping Konica Minolta come up with a modified version soon!.
    โ€‹
    • Ziggy
      • Feb 2018
      • 802
      Hello,
      F/W G00-J9
      I dont think it is a firmware issue but J9 is pretty old current firmware is N4. when you update firmware you also need to update function version. current function level is 2.1 you set it by setting sw25 to hex 30.
      as far as fusing make sure paper weight is set correctly
      • jwai
        • May 2018
        • 517
        Paper weight is correct, client only use 80gsm paper and plain paper is set on machine.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          I've not had one last life yet, seem to have random blisters happening around the half way mark. Not impressed.
          • suomi
            • 152
            No part has lasted as promised....
            • copyman
              Owner / Technician
              • Sep 2005
              • 4778
              Not sure for this model but there is firmware for the 8 series addressing this issue mostly for 1st page after coming out of sleep mode.
              Have you gone into the service mode and increased the fusing temp?
              Aftermarket toner?
              • avecosat
                • Jun 2012
                • 305
                I've had that problem a couple of times on a C250i and I'm trying to get it from KM under warranty.
                  • 8205
                  We also have a long wait to get them from KM. They simply tell us 'sorry we don't have an ETA'
                  Very poor UK dealer support.
                  โ€‹
                  • jwai
                    • May 2018
                    • 517
                    Aftermarket toner?
                    I increased fusing temperature to +5 and +10, same result, genuine toner is using.
                    After print 2 pages , i check fuser side temp. it dropped to 8X degree and than raised to 11X degree.
                    tested same method on one C224, the temp. stayed on 12X degree.
                    • jwai
                      • May 2018
                      • 517
                      In addition i found, print color page is ok, print black documents mostly have this issue, all toners are genuine.
                      • NickHilner
                        • Sep 2015
                        • 1
                        Hi Jwai
                        We had exactly the same problem. We swapped the Belt and Pressure roller and Lamp from working fuser and still black wouldn't fuse and colours were fine.
                        We replaced the Themistor and seems like it is working now.
                        • jwai
                          • May 2018
                          • 517
                          Originally posted by NickHilner
                          Hi Jwai
                          Thank you for your great advice, i try to replace thermistor kit and test it.
                          • B0265
                            • Jan 2007
                            • 718
                            We have experienced this problem a few times lately, is there any new information?
                            • avecosat
                              • Jun 2012
                              • 305
                              +1 Does no one have new information?
