458E fuser issue
  • emujo2
    • Mar 2017
    • 1579
    458E fuser issue
    458e. Power on and device comes to ready to print. Fuser (non IH) is cold to the touch, service mode shows 190 c and fluctuating. Constant fuser jams..What in the world could be telling giving the false temp reading. We have replaced fuser, fuser control, main board with no change. Any ideas? E
    • 23010
    Re: 458E fuser issue
    Well I can't find the specific pins, but the thermistors go to the MFP board, and the lamps go ... well somewhere else. And the somewhere else must be the DC power supply. That would be my next stop. =^..^=
    • tsbservice
      Field tech
      • 8064
      This is hardly to believe. How it can be? I recently saw your post about brand new fusers for C450i have taken power supply and fusing drive but that sounds like you are in bad bad series...
      Like BC said PS may not fire up lamps but it must code and not reading 190 degrees.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4785
        This is very strange! Just to be clear the fuser is cold but no fuser trouble code because machine shows (thinks) proper temp 190c?
        You can rule out bad thermistor, and anything else with the fuser since you replaced.
        I would of guessed the main board but since you also replaced that only other thing I can think of is the pwr supply as Black cat posted.
        Since it's such a strange issue have you tried initializing the machine? Perhaps Firmware update.
        • emujo2
          • Mar 2017
          • 1579
          Well you can choose not to believe me, but I ran it by the tech twice..Serivce mode shows 190 and fluctuating, fuser is stone cold, no startup errors.
          • tsbservice
            Field tech
            • 8064
            I didn't say I don't believe you it's just hard to believe such an issue. Of course I believe your words as I never have even doubts in them. I only can wish you good luck as in this case you will need it.
              • 23010
              You could pin out the wiring harnass for the thermistor wiring ... that could account for false temperature readings theoretically. =^..^=
              • copyman
                Owner / Technician
                • Sep 2005
                • 4785
                wouldn't hurt to try the log acquisition tool to see if any codes are being registered in background. see attached
                • Gift
                  • Mar 2011
                  • 2459
                  That's pretty interesting - never heard of this tool, thanks!!
