Bizhub c308 DF-629 Line
  • mrfuser
    • 1626
    We have a client with a DF-629 that is making a line all the way down the document in the feed direction on the NON OP side of the document when scan to copy. Off the glass is fine, prints are fine. Can't find a solution on the konica site for this nor in any documentation.
    Any ideas?
    Thanks!
    K
  • Ziggy
    • Feb 2018
    • 802
    Re: Bizhub c308 DF-629 Line
    Any ideas?
    Thanks!
    K
    Clean the small glass to the left of main glass
    • mrfuser
      • 1626
      [/QUOTE]
      • Gift
        • Mar 2011
        • 2459
        Does it occure on scans, too? Can you provide a sample?
        • Synthohol
          Certified Konica Expert
          • 5892
          NON OP side
          what does that mean?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4764
            Originally posted by Synthohol
            NON OP side
            I was thinking same thing. Never heard of "OP"
            • tsbservice
              Field tech
              • 8052
              I would guess OP=operation panel.
              I would start by redoing ADF setup adjustments.
              • Todd Glenn
                • May 2021
                • 22
                Does it appear on the lightest exposure setting with ADF, or with darkest setting off glass? Tried adjusting the read position, where the scanning takes place?
                • mrfuser
                  • 1626
                  non operators side, towards rear of machine. Sorry , old school term
                  QUOTE=Synthohol;2289779]NON OP side
                  what does that mean?[/QUOTE]
                  • mrfuser
                    • 1626
                    See sample below. The purple line running down.
                    • Tech09
                      • Apr 2020
                      • 147
                      Does it appear only while using the DF? You can also manually feed a piece of paper through the DF while it's open, maybe the paper is catching something and pushing it through. On very rare occasions I have seen dirty optics, something on the mirrors themselves, cause lines like the typical scan lines due to a dirty scan slit glass. The biggest tell is if the line goes all the way edge to edge or if there's a deletion at the edges, if there's a deletion then it's optics.
                      • mrfuser
                        • 1626
                        Only way I can get rid of. It was to go into service mode under machine/scan area and make the adjustment there.
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4764
                          [/QUOTE]
                          Lol, there's no "older school" than me (45 yrs in business) and I've never saw that term but makes sense.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4764
                            So just to be clear did that adjustment fix issue permanently? I've never seen that and want to make sure so I know the fix if I ever see it.
                            • mrfuser
                              • 1626
