Biz Hub c458
  • copierlady
    • 338
    Biz Hub c458
    Looking to purchase some older machines Biz Hub C458. Any thoughts on these models? I have been away from the Konica Minolta for a while not really my choice even though that is where I started many years ago. Do you still have to replace ALL the drums and DV at the same time or will this machine allow for one replacement at a time? Also can you swap out components from other machines for diagnostic purposes or are they proprietary?
    Thanks guys
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Biz Hub c458
    Do you still have to replace ALL the drums and DV at the same time no
    will this machine allow for one replacement at a time? yes
    a few boards can be swapped however some are married to the original machine and are a real duckfart to adapt to the new machine. (if at all)
    • copier tech
      • 8200
      Re: Biz Hub c458
      Thanks guys
      Out of all the KM models I would say the 8 series is one of the best & most reliable model.
      The later i series seem to have a number of issues & are not so well built.
      • tsbservice
        Field tech
        • 8052
        Re: Biz Hub c458
        I would just add 'Go for them!'
          • 23010
          Re: Biz Hub c458
          If you really liked the xx4e series (like most of us), the xx8 series is almost as good. The xx4e series could conceivably get 200% yield on drums and developing units. That will never happen on the xx8 series. If you get 100% yield, that unit is done ... finito. Otherwise very similar. =^..^=
          • kingarthur
            • 1385
            Re: Biz Hub c458
            i like the 8 series, most of the drums go way over life, had a C458 that had gone 3 and a half times it's life (350%), i know of a C308 that has Magenta drum currently at 237% and its Yellow drum at 175% , but it's the only thing i insist on using genuine KM parts, I've tried compatible drums and they are sh*t, i do convert black drums to colour though
            • tsbservice
              Field tech
              • 8052
              Re: Biz Hub c458
              Same here with K drums conversion. I think drums last past life in machines with low coverage but highly used. Any one seeing low monthly counts and 7-8% coverage and drums are ready to be replaced before their duty cycle.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4764
                Re: Biz Hub c458
                I still like the 4 series better than the 8 series. I haven't had good luck with the drums lasting in the 8 series. As I've mentioned before PCR rollers suck for copier drums and should be used on desktop printers only. I'm sure this was planned by Kon/Min to sell more drums.
                • Hansoon
                  • Sep 2007
                  • 3391
                  Re: Biz Hub c458
                  Besides of that possibility, could it be also because of as an attempt to reduce the ozone production in the machine?
                  • tsbservice
                    Field tech
                    • 8052
                    Re: Biz Hub c458
                    Yes. Evidence is lack of ozone filter in 8 series.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4764
                      Re: Biz Hub c458
                      Yes good point.
                      • Gift
                        • Mar 2011
                        • 2459
                        Re: Biz Hub c458
                        That's true but I doubt this was the most important argument during the decision process towards "let's do charge rollers"
                        C458 and the 8 series in general is pretty OK though, we refurb them a lot for another 36+x months in the field.
