BH-363, main switch off and on
  • Hansoon
    • Sep 2007
    • 3355
    I have many of these machines but never encountered this message:
    "Switch main switch off and on" (or WTTE)
    HDD, Memory, Boards?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5746
    Re: BH-363, main switch off and on
    does not appear to be an error.
    what happens after you do what it says?
    • Hansoon
      • Sep 2007
      • 3355
      Remains the same, even when the mains plug was pulled longer than half a minute.
      Will go there tomorrow with "frimwar", HDD, Memory, boards and some luck.......
      Hans
      • emujo2
        • Mar 2017
        • 1580
        Used to get that kind of cryptic message when Vcare stopped being able to reach the outside world, but this is a little different..I would search the manual and see if there are any codes that will flip the main power input to the machine..maybe a trouble reset and watching for fuser issues. E
        • Hansoon
          • Sep 2007
          • 3355
          I did, but found no answer yet in the Tech Manual from 2014/01/27. Perhaps the search function of my PDF-XChange is weak?
          Hans
          • emujo2
            • Mar 2017
            • 1580
            You need to get into service mode before it throws that message..Starting the trouble reset sequence should allow you to get to service mode and look at the error codes being generated. E
            • tsbservice
              Field tech
              • 7929
              Exactly what I would do.
              Can't remember but do these have some kind of self diagnostic like newer models?
              • femaster
                • May 2011
                • 1470
                The 3-series machines like this do not. I believe that started in newer firmware versions in the 4e models.
                • tsbservice
                  Field tech
                  • 7929
                  Hans, found this seems you may have bad HDD:
                  Bizhub 363 turn main switch off and on
                  • Hansoon
                    • Sep 2007
                    • 3355
                    Thank you so much. That confirmed my first idea and is exactly what I need.
                    Thanks to everybody here
                    Hans
                    • Hansoon
                      • Sep 2007
                      • 3355
                      Re: BH-363, main switch off and on **** SOLVED ****
                      Problem solved. I exchanged the HDD and the machine is up again.
                      Thanks guys
                      Hans
                        • 22960
                        Congratulations Hans. Thanks for posting back. =^..^=
