BIZHUB C554e error after been deconencted from the main supply
  • handixx
    • Apr 2023
    • 18
    #16
    Re: BIZHUB C554e error after been deconencted from the main supply
    So :
    make sure everything is enabled in problem unit isolation.
    all was disable, after turn it on now i have a lot of error saying nothing is available
    make sure the proper feeder is selected (624/701) in system 2 adf settings.
    I have changed for the good one.
    select and verify machine and type when booting to a firmware stick.
    yes it's was the good one when I made the upgrade.
    Unfortunately I couldn't print or save on the csv file the parameter of the machine before make the upgrade. Do you know if there is a easy way to do it ? .
    Anyway I glad to have you using your time to help me !!
    • tsbservice
      Field tech
      • 8053
      #17
      Your consumables may be over life and machine won't print because of that.
      Can you post consumables life list?
      • handixx
        • Apr 2023
        • 18
        #18
        I don't think it's breakdown a week ago before that all was working well.
        This is the list of counter and the list of error
        • handixx
          • Apr 2023
          • 18
          #19
          • tsbservice
            Field tech
            • 8053
            #20
            [ATTACH=CONFIG]57871[/ATTACH][ATTACH=CONFIG]57872[/ATTACH][ATTACH=CONFIG]57873[/ATTACH]
            All four drums are over life and that is the reason.
            • tech51
              • 846
              #21
              If you press job list, go into the job log, highlight a failed job and press details.
              This should give you a clue as to why the job failed.
              • tsbservice
                Field tech
                • 8053
                #22
                I bet my money on stopped print or similar.
                • Synthohol
                  Certified Konica Expert
                  • 5892
                  #23
                  when i said make sure everything is enabled in problem unit isolation, i didnt mean set them all to be isolated.
                  konica has a way of saying things in reverse like when you want to disable sleep mode you go to sleep on/off setting and the choice is permit or not permit so you would think not permit means you dont want to permit it to sleep. this is not the case. it is to permit or not the display of being able to select do not sleep in admin mode. crazy right?
                  i see how you assumed set or unset means the opposite of what i was asking to check.
                  i hope its all straightened out.
                  did you check the life stop setting and set it to do not stop?
                  you may get lucky.
                  • tsbservice
                    Field tech
                    • 8053
                    #24
                    Hi, all done,
                    look like working again !! I have just a alarm asking me to replace all my drum unit..
                    Can we reset that , because they are almost new ><
                    Seems they are not is where you lost me...duhh Frenchmans are so good in cooking for others but nothing more.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      #25
                      i dont think you can disable life stop after they go over it had to be done prior. now it has forgotten it was ignoring life limits you now have no choice to replace them or re chip them. unfortunate side effect to the original fault
                      • handixx
                        • Apr 2023
                        • 18
                        #26
                        you may get lucky.
                        I didn't get it !! so yes now it's better when nothing is enable .
                        I have the pleasure to tell you that : I made a copy !!
                        just la last error, the animation staff... when I made the upgrade i din't put the .tar because I didn't knew where I have to put it.
                        how it's work ? I put it on the root and boot on the usb ?
                        and the cherry on the cake, when the machine is powered, i mean not in low power mode setting I hear a "oiiiiiii oiiiiii oiiiii". where should I inspect to know which moving part I have to replace ?
                        • handixx
                          • Apr 2023
                          • 18
                          #27
                          the problem wasn't there, it's was a misunderstood about the enable thing
                          • handixx
                            • Apr 2023
                            • 18
                            #28
                            it's work you can disable
                            • Synthohol
                              • 5892
                              #29
                              tar file on the root and its installed in install data in service mode, system input install data.
                              • handixx
                                • Apr 2023
                                • 18
                                #30
                                ALL GOOD !! the machine work like before the main supply issue !!!! THANKS A LOT !!
                                do you have a glue to gave me for the noise ?
