Re: BIZHUB C554e error after been deconencted from the main supply
So :
all was disable, after turn it on now i have a lot of error saying nothing is available
I have changed for the good one.
yes it's was the good one when I made the upgrade.
Unfortunately I couldn't print or save on the csv file the parameter of the machine before make the upgrade. Do you know if there is a easy way to do it ?
Anyway I glad to have you using your time to help me !!
So :
make sure everything is enabled in problem unit isolation.
make sure the proper feeder is selected (624/701) in system 2 adf settings.
select and verify machine and type when booting to a firmware stick.
