BIZHUB C554e error after been deconencted from the main supply
  • Synthohol
    Certified Konica Expert
    • 5892
    #31
    Re: BIZHUB C554e error after been disconnected from the main supply
    please record the noise on your phone and post it here.
    • handixx
      • Apr 2023
      • 18
      #32
      I don't know why the upload isn't working.
      here the file by wetransfer
      The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
      • femaster
        • May 2011
        • 1519
        #33
        https://we.tl/t-cxF7gsCVDg
        With it sitting idle like that and squeaking, you are looking at the fuser and/or the drive unit for the fuser. You might be able to get away with lightly oiling the bearings / bushings in both, but with it that loud, your may be looking at the need to replace parts. Power down the machine and remove the fuser. Locate the large drive gear on the right side of the fuser and spin it by hand and see if you can hear any squeaking. If yes, start there. If no, look to the gear box that drives the fuser. Noises are always fun!
        • Synthohol
          • 5892
          #34
          Re: BIZHUB C554e error after been deconencted from the main supply
          That's the oil roller bushings.
          Remove the 2 side and front cover and you can remove the oil roller and holder.
          One or 2 c clip and its out. No more noise.
          • handixx
            • Apr 2023
            • 18
            #35
            thanks for your advice,
            I will check that and keep you in touch. Not sure that will be today but it's will be on the week.
            • handixx
              • Apr 2023
              • 18
              #36
              Oke, I have took of the fuse, cleaned inside and there is no sound anymore.. I suppose it's will not be for a long time !!
              I do understand where I have to look about the "oil roller and holder" if someone have a picture I will be grateful if it's can be shared.
              How I can change the title of the thread to add resolved ?
