C250i has clicking noise
  • Terrocks
    • May 2023
    • 10
    Hello, I have a brand new C250i out of box. When doing my set up I noticed that there is a clicking noise before the fuser actuates. I have located the problem by using load check. Specifically 45-7. It seems the fusing pressure motor will not release. I was wondering if anyone had any tips or tricks to try before I return the fusing motor assembly for a new one. Thanks!
  • tsbservice
    Field tech
    • 7926
    Re: C250i has clicking noise
    Another fuser tried?
    • barber782
      • Aug 2011
      • 279
      Had this on a c450i, I levered the pressure retraction gear/shaft forward to allow better meshing with the fuser gear. See attached photo. Alternatively you can realign the fuser drive assembly.
      Not sure if this is related to the loud banging/juddering noise some customers have reported. Sounds like a jackhammer. Anyone else had this? Fuser pressure drive.jpg
      Sent from my VTR-L09 using Tapatalk
      • copyman
        Owner / Technician
        • Sep 2005
        • 4544
        I just had a fairly new C450i making clicking sound and it was the Waste Toner Conveyance ASSY (#11 in attached). Lubed the gear (arrow in attached) and noise went away and has been good. Might not be your issue but may help someone else.
        • Ziggy
          • Feb 2018
          • 684
          I have had a few that I had to take off back cover and push the drive for the fuser cam gear a little towards the cam gear on fuser. Kind of hard to explain I'll try to take pictures next time. pull out fuser first. .
          • femaster
            • May 2011
            • 1469
            Not sure if this is related to the loud banging/juddering noise some customers have reported. Sounds like a jackhammer. Anyone else had this? [ATTACH]58267[/ATTACH]
            We've had this on 2 different i-model machines. For some reason the pressure drive is out of wack and doesn't meet up with the gear in the fuser properly. A different fuser made no difference. We ended up doing the same thing on both of them, muscled the drive unit forward some and then it worked fine with no further noise. I'm wondering if maybe the 2 we had were man handled a bit on the delivery truck or at the warehouse.
            • Ziggy
              • Feb 2018
              • 684
              Sounds like you did same thing as me. The ones I had trouble with were new out of box. I think its a manufacturer defect, like a slight wrap in frame
                • 8106
                Had the same issue with this part mine was making a really loud high pitched squeak.
                • B0265
                  • Jan 2007
                  • 718
                  We have also had this 3-4 times, I'm pretty sure it's a tranportation damage, the frame where the fusing drive assy is mounted is a bit week on this series.
                  • occus
                    • 326
                    I had one that a customer filmed, I replaced the fuser, but the allegedly defective fuser worked wonderfully in another device.
                    The second one where I thought it was the clogged transferbelt which it wasn't. The noise has not appeared for 1.5 years
                    And yet the third customer reported a c250i making loud noises but when I visited I couldn't find anything and haven't shown up for 2 months.
                    I've never seen or heard it live myself. Only on the video.
                    • Gift
                      • Mar 2011
                      • 2447
                      Did you remove and visually inspect the ITB cleaning + pipe?
                      We had cases with intermittent machine gun noises and I think the sound is a bit louder during
                      the camera was close to the inner + front/left area of the machine.
                      • occus
                        • 326
                        On the first device from the video, the problem could be heard 2-3 times according to the customer. After replacing the fuser the noise was gone. I have not had an inspection for 1.5 years. That's why I didn't check the ITB after.
                        With the second device, the noise also appeared several times and it sounded like ITB to me. So I checked the ITB and the cleaning unit and the hole path down to the wastetoner but there was no hardened toner in it. A C-3103 was listet so it seems it was a fuser problem. I left everything as is and it has been working for more than a year.
                        The third device with counter about 5k is 30 meters away a from me at the neighbor's and I haven't done anything, I've been waiting for it to appear again since 2 months.
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4544
                          My mistake, after checking the work order noise was a squeak not clicking. Disregard my post for clicking noise.
                          • Terrocks
                            • May 2023
                            • 10
                            We have swapped multiple fusers to no avail. I will try to manhandle the motor assembly into place to hopefully mitigate the noise so that the gears mesh a little better. Will keep you all updated.
                            • Terrocks
                              • May 2023
                              • 10
                              We have decided that the best course of action is to call Konica to see what they say about it. We don't want to go smacking the motor in before letting them know what's happening. Thanks for all the suggestions everyone!
