konicaminolta c3070L
  • chughtai
    • Sep 2021
    • 25
    [Misc] konicaminolta c3070L
    hi
    expert's for konicaminolta i have a problem for accurio C3070L for banding for 100 to 300GMS paper and cards i did every thing according to service manual.
    i adjust fuser speed and change fuser unit and transfer unit assy but not solve problem i also swap drum unit to other machine but problem
    still same. i attach print photo sample. plz kindly give me your advoice
    if any one face this problem plz help me to find out this problem.
    thanks.
    • 23010
    Re: konicaminolta c3070L
    Are you setting the correct media type for your media?
    • chughtai
      • Sep 2021
      • 25
      yes i have art card and balech card and matte paper 100gms but still same problem
        • 23010
        There are a number of defects in these images. Can you please mark which defect you are concerned about, and which direct that the paper fed? =^..^=
        • Synthohol
          Certified Konica Expert
          • 5868
          swap corona units and see if it follows them since a drum swap did nothing right?
          • chughtai
            • Sep 2021
            • 25
            left sarrow for feeding side
            • Synthohol
              • 5868
              what are the consumable counters at?
                • 23010
                Thanks for marking up the images. So the defects are crossfeed? Does it affect CMY images also? Does the defect change?
                I think that I would start with the black drum. We've had new drum units in which the rear drum bore is milled to small, so the drum does not insert properly when you slide the drawer shut. To test out this hypothesis, remove the transfer belt assy, and all the drums and developing units, then insert just that single drum unit into it's spot. Then slowly slide the imaging drawer in to confirm that it closes smoothly, all the way, so the front frames touch. Lubrication does not seem to help this issue. I used a rat-tail file to open up the rear bore, just enough to allow the drum to fully insert.
                The black developing unit could be difficult to turn also. I've also had the transfer belt unit bearings seize up at high count. =^..^=
                • Ziggy
                  • Feb 2018
                  • 789
                  If only the black is doing this
                  To test and see if the black dev unit is problem you and swap the black and one of the color dev units (ex. Cyan). Just be sure to put scotch tape over the hole where toner goes in to the developer unit on each unit. Then boot straight into service mode and run 1 cyan test chart at 128 density it will come out black because of swap. if it still has bans then you have a bad black developer unit. Only run 1 print to test if you run a lot it will make a mess due to toner trying to add.
                  • Synthohol
                    • 5868
                    if you leave the toner door open it wont try to add toner during testing like described above.
                    • Ziggy
                      • Feb 2018
                      • 789
                      I've never tried it that way, that is a good idea. But wouldn't you still get a small amount of toner drop in the developer unit when you pushed them in?
                        • 23010
                        That's what the tape is for. the toner cannot pass through the tape. =^..^=
                        • chughtai
                          • Sep 2021
                          • 25
                          thanks for you response i have to machine in same location i swap machine-1 all drums, developre unit, charger assy and transfer belt unit other machine-2 but machine to working wil machine-1 still same issu not only black all color CMYK i am only upload black image.
                          what you think it possible for high voltage unit?
                          machine-2 part still new only 168k prints.
                          thank's
                            • 23010
                            thank's
                            Just to clarify:
                            You have two machines in the same location, so you have swapped all drums, all developing units, primary charge units, and transfer belt between machine-1 and machine-2.
                            I am not sure which machine had the problem initially, machine-1 or machine-2, but the problem remains with the original machine after all consumables swapped.
                            You only provided samples of black, but the issue affects all colors.
                            Do I think the HVT is likely? No.
                            Do I think a laser unit is likely? No, there are four separate laser units, and it's unlikely that you would find four defective laser units at once.
                            What would I do?
                            I think I would start by doing a power quality analysis. How clean is the wall power?
                            I would use 13 x 19 original size and print single color image samples, then emergency stop the machine, to determine if you see the defect:
                            1) on the drum
                            2) on the primary transfer belt, after primary transfer and before second transfer
                            3) on the paper, after second transfer and before fusing
                            In this way you can determine at which stage the image is affected. Would you like original images? See attached: =^..^=
                            • Todd Glenn
                              • May 2021
                              • 22
                              Is the second transfer roller making contact with the electrode?
