Konica 550i
  • antone
    • Oct 2014
    • 344
    Konica 550i
    4 machine's updating firmware 2 machines boots up 50 percent of the way black dot goes way.than goes into copy screen....I used 4 USB sticks. Used the top port and side port help
    Sent from my SM-S918U using Tapatalk
  • tsbservice
    Field tech
    • 8020
    Re: Konica 550i
    Try another FW version. Happened to me.
    • Synthohol
      Certified Konica Expert
      • 5847
      Re: Konica 550i
      try a trouble reset first.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4718
        Re: Konica 550i
        Have you tried selecting each item individually and update FW one at a time?
        How far is the jump between FW versions? You may need to update in steps using older FW versions first.
        And last thing is to leave front door open after black dot appears. This use to work on the "8" series, not sure about the "i" series.
        • occus
          • 337
          Re: Konica 550i
          Do you have different +550i with and without memory board? They need different versions of firmware.
          • Ziggy
            • Feb 2018
            • 770
            Re: Konica 550i
            looking at Konica's firmware page there are two P8 firmware's listed both say without memory so that is an error. One is with memory and one without , one file is is in folder FW0025 and the other is in folder FW00026. If you put both of these firmwares on the root of a usb the machine will only pull from the folder that it needs. It wont pull the wrong firmware.
            • rrrohan
              • Sep 2011
              • 1977
              Re: Konica 550i
              back in the day when ever usb/CF card update wouldnt work i used ISW. maybe try that
