Konica C450i Account Track
  • hayhay
    • Sep 2023
    • 3
    Hi everyone,
    I have a Konica C450i that I am trying to enable Account Track on. I can enable it and choose for the copier to use "Password Only". I then put that information into the printer driver on the PC. Whenever I try to print, the copier receives the job and then deletes it due to "Login Error". I have verified multiple times that I am setting up Account Track correctly (and I have done it on other Konica machines with no issue).
    I am not sure how to resolve this issue or if anyone else has had this issue before. Any advice would be appreciated.
  • copyrooks
    • Oct 2013
    • 210
    Re: Konica C450i Account Track
    Make sure you have the correct driver for the model you are working on, in my experience it will never go through unless that is correct.
    • hayhay
      • Sep 2023
      • 3
      • copyrooks
        • Oct 2013
        • 210
        The driver software file for c360i should have the c450i driver also. You might want to use the setup 64 file so it can find and pick the right one. If you have to install through windows print and scan install the c650i driver and then manually change to c450i on printer properties menu drop down box.
        • strider5555
          • Jun 2008
          • 96
          Had a similar issue on a C450i. Could not get secure print to work. First it was because IT installed a B450i driver, but even after installing the correct driver it still didn't work. You need to use the C650i Series driver. We tried everything, including a data clear and still it didn't work. Then we saw that on PSWC it showed a generic 45 ppm machine instead of Bizhub C450i. Checked software switch 10 and it was set to Hex 02 correctly. What we ended up doing was setting SW10 to hex 00, fix and reboot, then set it back to hex 02. After that everything worked properly for us. Just a note of caution, changing this switch will reset all network settings.
          • hayhay
            • Sep 2023
            • 3
            I will try this tomorrow, fingers crossed it works for my issue also! Thank you!
            • Ziggy
              • Feb 2018
              • 802
              Make sure the firmware is at P8 and function level is 2.2
              • rrrohan
                • Sep 2011
                • 1977
                ive had a lot of customers installing the non i version drivers.
                • copier tech
                  • 8200
                  Originally posted by hayhay
                  Hi everyone,
                  As others have said check you have the correct driver install also update the firmware & function version to 2.2. (SW25 HEX 3.0)
                  • copytechtrouble
                    • Nov 2020
                    • 112
                    Hi everyone,
                    so you definitely have your password entered and verified under 'printing preferences - basic - output method - account track'?
                    • HuronMan
                      • Jul 2009
                      • 68
                      conf.jpgYou have to choose the right model under settings in the configure tab or it won't work.
                      • louisd
                        • Jan 2025
                        • 1
                        I'm also having troubles with getting account tracking to work with our C450i. Using the C650i PostScript drivers.
                        HuronMan, I don't see the Model device option on my end 🤔
                        • Synthohol
                          Certified Konica Expert
                          • 5892
                          whats on the advanced tab?
                          • Duplicator
                            • May 2022
                            • 255
                            That's because you are using the device specific drivers. You can pick a different model on the universal ones. It will show the current driver installed on the advanced tab.
                            Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                            If I helped you out, please give me a thumbs up! It helps my reputation.
