Bizhub c754 Data is being processed after data recovery
  • mrfuser
    • 1626
    Screen is stuck on "data is being processed do not turn the power off" and has been that way for hours. Any idea how long this takes?
    Thanks all
    K
  • Ziggy
    • Feb 2018
    • 801
    Re: Bizhub c754 Data is being processed after data recovery
    Thanks all
    K
    Sounds like you have a boat anchor. Ive never had it take over 5-10 minutes tops on a 4 series. What were you doing or trying to do when it started this?
    • mrfuser
      • 1626
      update firmware . Seemed like the update went well and all said finished then reboot to error
      QUOTE=Markks;2482662]Sounds like you have a boat anchor. Ive never had it take over 5-10 minutes tops on a 4 series. What were you doing or trying to do when it started this?[/QUOTE]
      • Ziggy
        • Feb 2018
        • 801
        [/QUOTE]
        Did you wait until the print button turned blue when you were updating firmware before you turned machine off?
        • mrfuser
          • 1626
          [/QUOTE]
          • Ziggy
            • Feb 2018
            • 801
            [/QUOTE]
            You could try running the reset tool? That might bring machine back
            • Ziggy
              • Feb 2018
              • 801
              reset tool bulletin attached
              • mrfuser
                • 1626
                I have a couple of donor c754 units. Could I use an ssd board from one of them to fix this? When we ran self diagnostics it shows pattern error on ssd
                • Ziggy
                  • Feb 2018
                  • 801
                  You can't use a SSD from another machine. I'm attaching a troubleshooting guide that might help you
                  • mrfuser
                    • 1626
                    Can we replace the mfp and ssd from another machine together?
                    • Ziggy
                      • Feb 2018
                      • 801
                      NO
                      • mrfuser
                        • 1626
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4762
                          I've swapped MFP boards from one 4 series to another with no issues. Just need to cleanse the board first (see attached). Also have used SSD with the MFP from another machine.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4762
                            Have you tried to load previous F/W version? Did you try a physical format on HDD?
                            • mrfuser
                              • 1626
