FS-536SD
  • copierlady
    • 338
    FS-536SD
    Hi Guys,
    Setting up a FS 536SD and the tray holder advanced up to far and is hitting the cover. Is there a way to make it go back down before I power up again? I know I have run into this before years ago but I cant remember what to do. I think it happened because the tray was not on when the finisher was setting itself up. Thought about taping down the sensors on the top and restarting. Just wanted some input before I try that.
  • Synthohol
    Certified Konica Expert
    • 5907
    Re: FS-536SD
    You gotta open the finisher door, hold up the actuators and close finisher door and the tray will think it's fill and it will lower.
    The other was is remove rear cover and depress the spring clutch gear so it Lowers the tray, that should be done with machine off .
    • copyman
      Owner / Technician
      • Sep 2005
      • 4785
      Re: FS-536SD
      I just remove the rear cover and turn the pulley that lowers & lifts the belt for tray
      • copierlady
        • 338
        Re: FS-536SD
        Thank you. I will give it a shot.
        • copierlady
          • 338
          Re: FS-536SD
          OK Got it. Thank you.
            • 23010
            Re: FS-536SD
            This is the way I would have told you.
            I used to use this one when shipping out finishers for delivery. It has to be lowered some to unscrew the tray. Our delivery guys were not always very delicate with the finishers (I don't mean you, Thayer). =^..^=
            • elmaligno
              Expert technician KM
              • Oct 2009
              • 302
              Re: FS-536SD
              Originally posted by copierlady
              Hi Guys,
              You can do it too in service mode,finisher settings, test , main tray up/down
              Field technician since 1994
              • Synthohol
                • 5907
                Re: FS-536SD
                When the upper limit switch is activated I have never had a response in service mode for lowering the tray, the error code usually cancels the ability.
                Ymmv good luck
